Home > Maintenance & Modifications > I have the engine :) it's a 3.2 :)
Page 11 of 14 <123 ... 1011 121314>
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I know what your busy is Whistle
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #192834 11th Dec 2012 9:17pm
bell-auto-services
lol
Post #192835 11th Dec 2012 9:18pm
big steve
i ordered a new number plate light from mobile centre the other day aslo looking at buying a load of stuff from devon4x4 to tidy up and sort out the wireing including proper cut of switches
steve 2015 2.2 tdci hardtop xs
Post #193448 14th Dec 2012 1:22pm
big steve wrote:
Also looking at buying a load of stuff from devon4x4 to tidy up and sort out the wireing including proper cut of switches
steve
Can't get a better choice than that. Wink TheThunderRolls🇬🇧🇺🇸
Post #193455 14th Dec 2012 1:47pm
Bear in mind they are still talking about a 'single mechanical' means of electrical isolation being required for comps ...
Post #193456 14th Dec 2012 1:49pm
big steve
i will do probly put in a proper hand cut off switch before the electronic one ?
Post #193464 14th Dec 2012 2:31pm
It all appears up in the air, the regulations state that the cut off should be mechanical ie a physical disconnection of the positive battery cable with 'one' movement - which is fine if you have a single battery and don't need to pull a lot of current through the switch - but as most of us have multiple batteries and Gigglepin 'style' winches pulling hundreds of amps this isn't very feasible.
I've seen a row of heavy duty (250amp) switches in a line in a buggy with all the handles joined together with a 'cam' type lever but not very practical in a Defender.
My solution was to have a 450 amp continuous rated double pole switch made for me by Albright (at huge expense) but that will only cut off two batteries ....
Lots are using electronic cut offs - I guess it's down to the scrutineers ....
Post #193472 14th Dec 2012 2:52pm
big steve
It's alive Smile
Post #193821 15th Dec 2012 7:15pm
big steve wrote:
It's alive Smile
Steve
Thumbs Up TheThunderRolls🇬🇧🇺🇸
Post #193822 15th Dec 2012 7:18pm
big steve
Lets hope Santa gets it back to me before Xmas Smile
Stevd 2015 2.2 tdci hardtop xs
Post #194085 16th Dec 2012 6:25pm
big steve
The cost so far !
I'm up �3000 from the sale of engine and cooler and other parts
Gearbox conversion from ashcrofts was �860
Allisport intercooler �420
Bmc air filter �400
Oil anti freeze and other choice parts inc sump �500
Allisport radiator �550 ( not actually needed ) but a choice item
Castings and new belt �120
Exhaust parts �120
The cost of wireing from BAS ?
The cost of the engine 5k with only 6miles on the clock
Probly other stuff I've forgot !
So in conclusion to this
I have spent about �7500 although I still have the BAS bill to come Big Cry go easy on me Pete
So up to Bowie spent 4.5k so I think this conversion if you do it yourself should be easy to get at around the 10k price depending on the cost of the engine ?
Post #194096 16th Dec 2012 7:15pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
It's not really unless we can see it on YouTube. Wink
Post #194097 16th Dec 2012 7:15pm
big steve
I've asked Pete to put up on here but he hasn't yet Sad 2015 2.2 tdci hardtop xs
Post #194099 16th Dec 2012 7:16pm
big steve
[img]https://www.defender2.net/gallery/albums/userpics/10851/3.2%20defender.MOV[/img]
lets hope this works Confused
Post #194221 17th Dec 2012 8:06am
Had to find it in your gallery, but sounds great Thumbs Up Darren
Post #194222 17th Dec 2012 8:10am
