Home > Off Topic > ATV alternative to a quad
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Have been offered a good supply of free wood, but how to get it out of said woodland is the problem.
There is limited access, and we will have to build a bridge across a small steam with sleepers, so we will need to be looking at a smaller size vehicle. We have used a Honda quad with trailer in the past, but the land has side slopes and the quad is unstable for my liking.
A land rover or the like is too big and heavy (unless we want to winch in and out all day) and so we are looking at a Kawasaki mule type atv, can anyone recommend the pros and cons of said completion, Kawasaki, Kubota, Polaris. We would like a good load area and carrying capacity.
Any input would be appreciated.
(It has been suggested, we cut our way into the woods and make a track as we go, so the use of a tractor would be ideal, but this is not an option, we only have access to felled trees and must leave those standing, standing).
Post #193054 12th Dec 2012 9:56pm
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I have just ordered a Polaris Ranger 900 xp had some really good reviews about 600 kg payload and 900 towing Thumbs Up
Post #193055 12th Dec 2012 10:19pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
A horse Whistle
Post #193056 12th Dec 2012 10:27pm
Green Machine
What size quad bike have used previously? Our family farm runs down off the North Yorks Moors down to the coast, so is pretty hilly! We have had Honda quads for years and use them for pretty much everything. The quad can go just about anywhere compared to the Land Rover, tractors etc. also use it to bring wood out of the woodlands dotted around the place. We currently have a Honda Foreman, and have had several Foremans before, along with various other Honda quads. The great thing about the quad is that the centre of gravity is relatively low and it's also light. Always amazes me just how much weight it can shift over bad going for such a small vehicle. I would have thought that a mule (with roll bar, tipping loadbed etc) is actually more likely to roll than a quad bike, because that added weight higher up raises the centre of gravity. Another consideration is that if a quad bike starts rolling, just jump off it and leave it to go. Not as easy when your actually 'in' a vehicle (probably not advised best practice, but ultimately it's what happens).
In the many years of using quads we've had one roll-over incident, which was caused by a combination of very wet slippy ground and a steep drop-off to the side of a steep track. The quad slipped to far towards the edge, and over it went. Driver jumped off the top side as it started to go, it barrel-rolled its way down the slope, landed on its wheels at the bottom and was driven home for a bit of hammer-based re-adjustment.
All I'm trying to say is that, in my personal experience, quad bikes are actually pretty stable (especially the wider 'utility' type quads). I don't have any first hand experience of mules, but I can't see how they are significantly better from a stability point of view, apart from the fact that some do have roll bars. OK, they're generally a bit wider but they're also heavier and taller. Just my 2p worth! Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #193061 12th Dec 2012 10:54pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
There are some 6 wheeled atv things with a tippy bed, or a JD Gator....
Post #193063 12th Dec 2012 11:00pm
boode
I would agree with Green Machine - we use Honda 500cc Foreman Quads on the farm and they are more stable on slopes than the mules. We have rolled our quad when spraying nettles on some very steep fields - the sprayer raises the center of gravity - but again as Green Machine says its easy to simple jump off and let the quad roll away. If your land is too steep for a quad bike then you will need something tracked - or a horse.
Post #193065 12th Dec 2012 11:04pm
christyler
ATV
you should check out the Argo, www.argoatv.ie
Post #193073 13th Dec 2012 12:21am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
The Argo is the best off road by far but for carrying a Polaris or Mule would be better. I'm not a big fan of the Polaris after seeing a few accidents with them. Some of the John Deere ATV can be found cheap.
Post #193074 13th Dec 2012 12:36am
JeremyJ
Are you looking new or used? We used to Mules but they all have problems with the four wheel drive system. Now running a Kubota RTV, great vehicle. Quieter and better to drive than the Mules with no transmission issues
Post #193078 13th Dec 2012 6:50am
I agree entirely with Green Machine.
I've owned quads for years and often traversed side slopes in recreational situations and find them very stable or at least being able to make them stable by hanging off the high side.
However, how much timber are we talking about, quads aren't cheap and it's all very well traversing a side slope in a quad but what about the trailer loaded with wood that you are hauling ? That is going to have a high centre of gravity and is just as likely to drag whichever mode of transport you are in / on down anyway I would have thought.
Post #193082 13th Dec 2012 7:17am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
argocat will go pretty much anywhere and floats Thumbs Up
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #193085 13th Dec 2012 7:35am
walfy
Remember you can get wheel spacers for quads. So increase the track width to help with stability. A lot of US based quad rider run anything from 1-2" spacers on the CanAms' I'm sure spacers are available for other makes..
I have a Grizzly 700. I am astounded the side slopes it crosses without tipping. In fact I have stepped off in preparation of a roll but the quad just sat there making me look a bit daft. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #193124 13th Dec 2012 12:30pm
ickle
I had a Honda 350 4x4 foreman for a few years pulling timber out of our fairly steep wood - I was always astounded at the weight of timber it would drag out, and when I got our first Freelander 1 well and truly stuck on tree roots and mud, it pulled it out with ease.
Honda quad all the way!
Keith
Post #193188 13th Dec 2012 4:52pm
Quad def better than a Mule Thumbs Up
Post #193189 13th Dec 2012 4:53pm
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Weve got a kawasaki 650, it likes jerry... The can! We did have the older type diesel mule and that was v useful but as was mentioned before, the 4wd is pathetic and we had loads of problems! Argo cats ive used on occasion and are really useful, amphibious too i think!?
Scott track is where the business is at! Pto 3 point linkage, tipper beds hiabs etc. fully tracked vehicle unlike the argos.
All depends on price! And im not anything to do with scott track btw! Just seen one on demo!
Good luck finding something! Thumbs Up
Wil
Post #193190 13th Dec 2012 5:02pm
