Home > Puma (Tdci) > Another temperature sensor
Page 2 of 2 <12
ericvv
Tks Brian. The EMS 1 and 2 surely provide the info. Just would be more interested if something could be fitted to make the standard coolant temp gauge in a Puma show the real coolant temp once this climbs to higher than standard working temp. And not just wait to move up until it reaches critical high temps. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #164532 26th Aug 2012 5:20pm
Lorryman100
Eric, I would think that the software would need to be rewritten in the IPAC to show the real temp readings?
Brian
Post #164533 26th Aug 2012 5:24pm
ericvv
Brian
If somebody would be able to come up with that solution, I am a buyer. Don't like this blob we have now. Would love to see the temp gauge show the real thing from min to max so that we can adjust our driving when necessary Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #164534 26th Aug 2012 5:31pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Lorryman100 wrote:
ericvv wrote:
And by the way, anybody knows what is the "ideal" coolant temp for our Pumas? I know with Mercedes they say this is 82�C.
Mine is 89-90 degrees with normal solo driving. Thumbs Up
http://www.defender2.net/forum/post76145.html#76145
Humm, I wonder about this coolant vs. CHT temp reading.
Assuming the water temp reported by the Scanguage is actually not the water temp but the CHT, I would expect the CHT reading to match the water temp (since they would be from the same sensor), right?
Well, that's not the case here. I usually read CWT (as reported by the std gauge on the SG) between 88/92 Celsius whereas CHT is much higher, usually between 95 and 100 degs Celsius, as reported and computed using the formula I posted here http://www.defender2.net/forum/post151519.html#151519
If that formula is wrong (which is obviously possible), I would still expect both values (CWT and CHT) to correlate perfectly. but that's not even the case, both values vary differently (but not complete opposite of course, they still follow the same trend), so it looks like different temperature readings from different sensors.
Please let me know if/where I'm wrong Wink
Post #192922 12th Dec 2012 11:27am
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
Hello,
I've ordered un scangauge for xmas, It seems to be exactly what I need to check what happen in yhe engine.
Thanks for your advices. Thumbs Up
Post #205371 25th Jan 2013 10:28pm
Page 2 of 2 <12
