Home > Technical > Headlamp wiring chaffed against wing edge
DAZ110
I found my drivers side headlamp main beam fuse blown.
The wiring had chaffed against the wing lip edge and caused a short blowing the fuse. This was next to the ABS pump position under the bonnet in the left corner.
Soon fixed with some insulation tape and slightly moving the position of the loom.
It might be worth you all checking your wiring so you don't have the same problem.
Post #19282 1st Dec 2009 8:53pm
110SEB
Thumbs Up
Post #19284 1st Dec 2009 8:57pm
