Home > Puma (Tdci) > coco the clown and my dashboard.
Page 2 of 2 <12
Be a bit careful pushing the centre panel back in. It usually fits properly quite easily and the fact that it hasn't popped into place makes me wonder if there are wires trapped between the panel and the rest of the dash.
Post #192724 11th Dec 2012 1:13pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Mine was exactly the same after I had the wiper motor replaced. Only realised the morning after as it was dark when I picked it up. Just loosened the lower screw and pushed it back into place.
Wasn't worth taking it back to the dealer, but that was mainly because they've always been good with every issue I'd had in the past, and this was the only 'niggle' I had with them.
In your case though considering how many issues you've had I'd be tempted to go back and kick up a fuss...
Did wonder if it was because of the aftermarket stereo, and the dealers don't have the correct tools to remove it properly?
Post #192730 11th Dec 2012 1:46pm
Might be I found with mine it put it slightly out of alignment. Nothing that a slight adjustment wouldn't sort out. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
Post #192732 11th Dec 2012 1:57pm
Caterham
black wolf - exactly what I was after .... I'll be careful.
fair comment about the stereo.
re; kicking up a fuss I have to say I was a little 'short' almost rude when after having transfer box work and expensive service undertaken that I should have to turn round and head back after only getting a mile or so down the road to notice the dashboard doing morse code !
turns out they'd not put an earth point back correctly ! Evil or Very Mad
Warren - same here. didn't notice till next day because dark.
Post #192737 11th Dec 2012 2:10pm
Killer90
Site Sponsor
after changing the wiper motor in the 110 the other day i had the same problem when i put it all back, basically slaken off the 3 screws int the top of the main dash one either end and one in the middle of the dash. Then push the center dash in and then tighten the 3 screws again Thumbs Up Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #192785 11th Dec 2012 6:04pm
Caterham
thanks killer. will have a look at the weekend when hopefully I can find the time.
Thumbs Up
Post #192899 12th Dec 2012 8:03am
Page 2 of 2 <12
