@Yobbie. Essesse?
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
Ordered - thanks 2007 TD5 90 Hard Top
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
Unfortunately not. ![]() ![]() |
A mate had the same combo... Puma 90, 500 Essesse though, I say 'had' as he swapped the 500 (wife's car) for a new 4 door M3 only yesterday! I love the 500
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
Not today but on Friday I stood out at a local meet.
![]() ![]() Click image to enlarge Ben Rebuilt 1996 black/white Defender 90 300 TDi |
WWA Member Since: 12 Aug 2012 Location: Northumberland Posts: 197 ![]() ![]() ![]() |
Hmmmm both great cars, but 500 over the M3 any day, more style and class. |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
Bolted on a bit more bling today. Well it is nearly Christmas...
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 617 ![]() ![]() ![]() |
Oooohhhhh they look nice - where did you get them from? |
CroyTec...
Baldinho Member Since: 28 Oct 2012 Location: Surrey Posts: 123 ![]() ![]() ![]() |
I've just swapped a 500 for a Defender! Agreed the sale then the airbag warning light came on...£425 to replace.... |
Me too as coincidence has it. Here's mine..
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
Took one of the rear mudflaps off as it's snapped a bit of the bodywork off, guess I should have done the fix earlier
Rewired the puma breather heater because I was unhappy that the heater (5amp draw) was running whenever the the key was in aux I position or the webasto thermotop C was running, so I took an ignition key position II feed and have wired it into another "heated rear window" switch so it's a manual operation, it only needs to be on when the temperature drops below -20C. The Ultra-gauge (thanks Brian) can be programmed to alarm when the airbox temperature drops below a certain temperature so I have a backup plan
Just a final few jobs before the trip |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3660 ![]() ![]() ![]() |
drove it from Brum to Cwm Cewydd and back now on 7200 and running loverly saw loads of defenders again at the Market in Welshpool Id say 50/50 Defender / everything else. DEFENDER 90 TDCI XS,
