Home > Maintenance & Modifications > Protecting roof paint?
Glynparry25
Kalispera,
With another project looming on the truck (I haven't even finished the current one) I am looking to mount a few items to my roll cage- I need to order items in advance as the always take soo long to get here.
Living out here has made me realise that leaving dirt on paintwork and then left out in the sun isn't a good idea. Out here it accelerates the rate that the paint then burns and peels off the metal. Have any of you put anything on your roof to prevent this happening whilst you can't clean it for whatever reasons.... roof rack etc?
I am looking at the possibility of some sticky back vinyl?........... any suggestions/ ideas?
Glyn Dog Sheep
Post #192056 9th Dec 2012 5:11pm
leeds
Personally I would be concerned about applying sticky back vinyl to the roof in a hot climate.
Would the adhesive plus heat attack the paintwork? Would the adhesive cure so much that the vinyl could not be removed from the roof when required?
Vinyl lettering stickers can be removed by careful use of a pressure washer to lift the edge of the lettering prior to peeling letter of.
Now is the adhesive used on lettering/stickers etc the same as that on sheet sticky back vinyl? If the answer is yes go for it, if no then proceed with caution.
Brendan
Post #192064 9th Dec 2012 5:30pm
Killer90
Site Sponsor
plastdip, paint the roof in that and that should protect it im sure they do it in clear but a matt black would look pretty sweet Thumbs Up no rubbing down etc just a good clean and apply the paunt- when you dont want it peel it off Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #192066 9th Dec 2012 5:43pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
You could try using a nano sealant like Gtechniq C1. It's used to protect paint from light scratches etc so may do what you need.
Post #192085 9th Dec 2012 6:42pm
All I can add to this is that vinyl letters are cut from rolls of vinyl, so yes, one and the same
Post #192089 9th Dec 2012 6:54pm
leeds
I agree and disagree with you Matt.
Am guessing that vinyl lettering comes out of light weight vinyl probably 60-80 microns. However there is also heavy weight vinyls used on furniture. Will the adhesive used on lightweight vinyls be the same as medium or heavy weight vinyls?
Am not sure hence why I say caution.
Now do we have an expert on self adhesive vinyls on the forum?
Brendan
Post #192109 9th Dec 2012 7:27pm
Glynparry25
Hmmmmm, a few things to think about.
Brendan, Matt is in the vinyl sign making business Thumbs Up
But.... when you mention furniture vinyl it makes me wonder what the roof will look like in a nice mahogany effect Cool
Glyn Dog Sheep
Post #192110 9th Dec 2012 7:30pm
Killer90
Site Sponsor
Glyn Dog Sheep
or leather roof Whistle Whistle CSK Automotive
Post #192112 9th Dec 2012 7:32pm
GUM97
Brendan
A heat gun is often a more effective solution of peeling the lettering off, although as you quite rightly said, a pressure washer also works fine Thumbs Up
As Matt has already said, vinyl lettering is made from a sheet of vinyl, so is the same thing.
3M offer a paint protection film, seen here: http://solutions.3m.com/wps/portal/3M/en_U...tion/Film/
The film is designed to protect the paintwork, and when removed is supposed to leave virtually no residue, which can sometimes be the case with ordinary vinyl. Hope that helps Thumbs Up An engine to TDi for!
Post #192114 9th Dec 2012 7:33pm
As someone who is an end user of wraps I can tell you it will damage the paint let no one tell you different 3m matamark makes fook all difference Thumbs Up
Post #192124 9th Dec 2012 7:52pm
leeds
That Scotch Gard sounds interesting!
Interesting what you can learn from the forum Thumbs Up
Now will Matt be offering Glyn a bespoke leather roof covering with silver stitching??? Shocked Razz
Brendan
Post #192126 9th Dec 2012 7:54pm
As Ken has said, vinyl wraps damage the lacquer when removed.
I think personally, I would put aside the money that you would pay out for a wrap to have the roof 'blown over' when you come to sell (or sell to a short bloke Whistle ), after all the vinyl itself will still mark so won't look any better
Post #192128 9th Dec 2012 8:01pm
Luismi
Spain 2004 Defender 110 Td5 SW Alpine White
Hi Glyn you mention that you have a roof rack and you want to install more things on it. You will consider to install this type of ply wood cover with aluminum like the G4 type off over your roof.
You improve the use of your roof rack reduce the temperature over the roof and consequently in the cabin
Post #192138 9th Dec 2012 8:23pm
MK
repaint the roof when necessary. Puma 110" SW
Post #192288 10th Dec 2012 12:11pm
