Home > Puma (Tdci) > SVX off set
WWA
United Kingdom 2012 Defender 110 Puma 2.2 DCPU Orkney Grey
SVX off set
Do SVX alloys have a different off set to boosts as stated here... http://funrover.com/featured/defender-wheel-options/
If so, is it much?
Post #192021 9th Dec 2012 2:40pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
I'll check for you later as I have both sitting in the garage.
Steve
Post #192022 9th Dec 2012 2:46pm
WWA
That would be great. Thank you
Post #192023 9th Dec 2012 2:49pm
SteveG
Just measured backspace on both and they are the same at 140mm ~5.5", so a positive offset of ~50mm/2" as both are7J wheels.
Steve
Post #192039 9th Dec 2012 4:24pm
SteveG
Also forgot to add that load rating on boosts is 1050kg, and 1000kg on SVX
Post #192041 9th Dec 2012 4:26pm
WWA
Thank you taking time to do that. I thought they would be the same. Cheers Steve
Post #192051 9th Dec 2012 5:00pm
nick67
Romania 2008 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
The original offset for Alu wheels is +38 mm for SVX. Defender SVX 2008
Discovery 3 HSE 2005
Discovery 1 300Tdi 1995
Post #192071 9th Dec 2012 6:01pm
SteveG
I looked again it's marked up as 33 on the alloys. This would account for me measuring from back of alloy for backspace, not using inside rim width.
Steve
Post #192079 9th Dec 2012 6:37pm
WWA
So they are still the same or has the SVX different?? Confused
Post #192080 9th Dec 2012 6:38pm
Glynparry25
Has to be wrong....... Why would you make a special edition wheel that sits even further into the arches?...... It would look terrible and you would have even worse steering lock!!
Glyn Dog Sheep
Post #192082 9th Dec 2012 6:41pm
SteveG
They measured the same, both are original LR wheels so they are the same.
Post #192088 9th Dec 2012 6:48pm
WWA
Thank you Steve. They even look the same on pictures, was just that website that threw me off. They still look the nuts though
Post #192241 10th Dec 2012 7:30am
