Home > Puma (Tdci) > LUBRICANTS FOR SERVICE
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Up till now i have had a 300tdi Discovery [12 years] so am quite familer with lubricant needed for the old girl
but now i am lucky enough to have just got an 07, 90 country hardtop in storneway grey
question is what lubricants are best used in. Engine
Gearbox
Transferbox
F&R Axle
So if someone could enlighten me with type,amounts and service intervals etc i would be very gratfull.
Post #19134 29th Nov 2009 7:38pm
mse
There are some posts on here with all the details Mike
Post #19135 29th Nov 2009 7:39pm
dgardel
Italy
My work:
Diffs.:
1. additive Bardahl T&D Fullerene (350 cc)
2. oil CASTROL SAF-XO synthetic GL5 class 80W-90 (fill up to fill-hole more or less 1250 cc)
Gearbox:
Gearbox type MT82 :
1. additive CPL Gearbox (125cc)
2. additive Bardahl T&D Fullerene (250cc)
3. oil Castrol BOT328 synthetic GL5 (oil 2050 cc) - NB!! remember that the fill hole IT IS NOT THE MAXIMUM LEVEL (like diff. and transfer box) , you need to fill the correct quantity (2,4 liters totally)
Transfer box:
1. additive Bardahl T&D Fullerene (250 cc)
2. oil Bardhal T&D SYNTHETIC OIL GL5 75W-90 (fill up to fill-hole ca 2050 cc)
After discharged the old oil:
- FIRST fill the additives
- SECOND add the oil
if you want to change the oils WITHOUT add additives:
motore = engine
cambio = gearbox
scatola del riduttore = transfer case
differenziale posteriore = Rear diff.
differenziale anteriore = front diff
The Castrol BOT 130M is superseded by Castrol BOT 328 fully synthetic GL4-GL5 80W-90 oil
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #19142 29th Nov 2009 9:05pm
MK
dgardel wrote:
My work:
Diffs.:
Gearbox:
Gearbox type MT82 :
Transfer box:
motore = engine
cambio = gearbox
Are you sure the BOT is GL-5? I think it is GL-4 and 75W/90.
As for the engine oil: Any oil meeting the Ford WSS-M2C913-A
Ford WSS-M2C913-B spec.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Puma 110" SW
Post #19148 29th Nov 2009 11:00pm
dgardel
Italy
BOT 328 YES!!! (If you want I scan the bottle) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #19149 29th Nov 2009 11:28pm
MK
Do you have a 3D scanner? Whistle Puma 110" SW
Post #19151 29th Nov 2009 11:56pm
roel
Maybe he can copy it so we have free oil. Roel
2003 90 Td5 (2009-now)
Post #19154 30th Nov 2009 6:24am
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
Thanks for the brilliant post Dgardel - very helpful Thumbs Up 110 Hard top
Post #19158 30th Nov 2009 8:31am
Naks
LR South Africa use the Castrol BOT 328 GL4 75w90 as well, but I cannot find any information on this oil on the Internet.
Even Castrol SA does not know anything about this oil, does anyone have the Technical Data Sheet?
On top of this, it costs a fortune: LR dealers - ZAR380/L whereas Castrol BOT 130M - ZAR120/L at various spare shops & Ford dealers.
Is Bot328 really 3x better than Bot130M!???
Post #54085 20th Jan 2011 10:46am
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
after some years Laughing , but,
Daniele, can you show me how is the ''bottle'' of this additive? can't find it......... Big Cry www.newfoundland.gr
Post #260580 22nd Aug 2013 3:34pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
http://www.bardahl.it/lubrificanti_additiv...ive.html#2 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #260610 22nd Aug 2013 5:44pm
dgardel
Italy
Grazie Marco Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #260709 22nd Aug 2013 9:21pm
Theater
dgardel wrote:
Grazie Marco
I learned the lesson of our teacher Daniele ! Wink
Thank you Daniele Thumbs Up Marco
Post #260790 23rd Aug 2013 9:57am
pouf
Grazie Marco !
ho sentito che fa miracoli questo liquido.
E dopo che professore Daniele gia usato, penso di provare anche io Rolling Eyes www.newfoundland.gr
Post #260797 23rd Aug 2013 11:05am
Theater
pouf wrote:
Grazie Marco !
Thumbs Up Marco
Post #260883 23rd Aug 2013 6:26pm
