![]() | Home > Td5 > Ebc discs and green stuff pads any good? |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 ![]() ![]() ![]() |
Not a very difficult job to do really have now fitted discs and pads all round. While I was at it I changed the callipers and wheel bearings too. I have a few pics and will put up when I get a chance.
The only thing I will say about the ebc green stuff pads is that they do squeek quite a lot under light braking that fades under heavier breaking. Work really well though ![]() |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 ![]() ![]() |
look forward to the pics... thank you in advance |
Riverblanche Member Since: 12 Sep 2012 Location: Retfordish Posts: 34 ![]() ![]() |
like Ret said..
seem to remember reading something about NOT using grooved discs as they fill up with mud if you venture off the black stuff and then act like grinding paste and wear the pads away. unless you steam clean everything off straight away I suppose ![]() |
