Home > Maintenance & Modifications > Rear windows dropping down!
familymad
Having just found the thread on 'door unlocks, re locks' and sorted that, the wife mentions that one of the rear windows drops down itself when we are driving.
Thought they'd have sorted that little one but alas no!
Did a search for a thread but no joy - anyone a fix for this 25yr old issue!
Cheers 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #189751 30th Nov 2012 9:19am
Reposition the winders so that gravity keeps them in the down position or, failing that, bungee cord to the pull handle seems to be the preferred option. It's not very high tech, but then sometimes things don't need to be. Darren
Post #189753 30th Nov 2012 9:22am
familymad
Love it. Great idea. I'm out bleeding the Series 3 fuels system so will do that right after!!
Cheers chappie 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #189754 30th Nov 2012 9:23am
Glynparry25
I noticed on mine the handle sits half way up on the cycle- so the weight of the handle is also helping the fact that the window wants to go down.
I have heard of people changing the handle around..... or taking some bungee and having it so it streches through the door handle around the winder knob.
I am sure someone will come along with another 'proper' technique of adjusting it though.
Glyn Dog Sheep
Post #189755 30th Nov 2012 9:24am
Killer90
Site Sponsor
Glyn Dog Sheep
remove the handle as Glyn said and turn it around so the heavy part is at the bottom Thumbs Up Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #189761 30th Nov 2012 9:57am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
After facing the handle down, maybe it might be possible to add a weight (perhaps like a stick on wheel balance weight?) to the handle ?
Post #189764 30th Nov 2012 10:28am
familymad
do you pull them straight off or are they fixed in some way? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #189765 30th Nov 2012 10:38am
The winder handles have a "U" shaped spring clip holding them on. If you press the panel towards the door you can just about see what needs to be done to remove them.
On my vehicle, the windows dropped irrespecitve of the handle position, so in the end I put a loop of bungee cord through the door pull handle so that it hooks round the knob of the winder to hold it shut. It was still necessay to position the winders for optimum angle of bungee pull however. It can also of course hold the window partially open if so desired in summer. It's rubbish really having to do this on a £30k vehicle, but hey, it's a Landrover!
It was always a concern of mine that if the windows vibrate open as they did, it would be possible for someone (with a rubber glove, rubber sucker, or similar) to push them down from the outside. In practice it doesn't seem quite that easy however.
Post #189766 30th Nov 2012 10:46am
familymad
I'm suprised that no-one has come up with a fix as everyone would buy it!?? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #189768 30th Nov 2012 10:51am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Retro-fit electric windows to rear?
Post #189777 30th Nov 2012 12:50pm
That's been on the "to do" list for about the last three years. It hasn't even made top of the list yet!
Post #189783 30th Nov 2012 1:24pm
I'm sure there'll be a stainless one for sale soon for a gazillion pounds. Wink Wink
Post #189796 30th Nov 2012 2:10pm
