Home > Maintenance & Modifications > Entreq door strips. Fitting. |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
For those who have these fitted, is the idea to use the included rubber seal once first removing the corresponding door seal or should I leave the door seal in place?
Seems like too many seals to me. |
23rd Nov 2012 4:16pm |
Just to add to the confusion....The seals supplied with the kit were redundant in my case as I have sill chequerplate. The Entreq strips slot behind the chequer.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd Nov 2012 4:34pm |
Good advice for when I fit the rear door strip.
I have sill chequer (Land Rover) too but my strips don't see to slot behind. My strips are the pre-12 ones. |
23rd Nov 2012 4:48pm |
Aaah! This might help. Can anyone translate for me please?
Click image to enlarge |
23rd Nov 2012 4:50pm |
4) Thoroughly clean and degrease the entrance area
5) At the door bases, remove the factory installed sealing strips and the small foam pads (in case they're still there). Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
23rd Nov 2012 5:01pm |
I knew it!
23rd Nov 2012 5:11pm |
another thing to note on the door strips, post MY2011 you need the non-seal version because the OEM door seals changed
23rd Nov 2012 6:09pm |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
At the risk of critising the emperors new clothes, the MY11 ones arn't worth the effort. They do not fit very well, and the additional aesthetic are marginal. IMHO of course, your experience may be better.
23rd Nov 2012 10:37pm |
Sorry duplicate post (seems easy to do here)
23rd Nov 2012 10:40pm |
I got mine mostly to pin the carpets down. Also protect the passenger sill from the bloody door seal (also+grit) scraping the paint off Tell someone you love them today because life is short.
23rd Nov 2012 11:09pm |
First thing I noticed when I bought the car was that it looked odd and unfinished without a strip to hold the carpet down.
Looks much neater now. In fact being all beautifully brushed and etched I'll probably go out of my way to avoid treading on it which is hardly thee point. Looks great at the back now especially with a full compliment of ss bolts in the rear cross member. Tyres next. |
24th Nov 2012 7:21am |
