Home > Technical > halfshafts
MK
halfshafts
Hi guys
anybody aware why >07 rear halfshafts are so expensive compared to previous models, ie. Td5?
Each is over 300GBP!!!!!
This is what you pay for Ashcroft´s HD ones. Both L&R hand.
thanks
M Puma 110" SW
Post #17625 1st Nov 2009 11:56pm
3WHouse
Russia 2007 Defender 110 Puma 2.4 SW Java Black
Salisbury - 300.
R classic - 260. Def`s 90 & 110 Monochrome.
You can go fast i can go anywhere.))
http://www.offroadpower.ru/
Post #17627 2nd Nov 2009 5:09am
Looking through microcat, the puma, and very late Td5 (from VIN 2A**** for 110, and VIN 4A**** for 90) share the same rear shafts TOB500030 & TOB500020 for both 90 & 110 and are £250.59 a piece.
however, looking at the earlier shafts, FTC4747 & FTC4748 have been replaced by the above ones, but they were only listed at £78 and £100 each (for short and long ones)
So you could use the earlier shafts (if you can still get them) and save a good bit of money, as they were just seperceded the earlier ones should fit in OK.
However.... as the later ones are considerably more expensive, you have to ask yourself are they any different? stronger maybe?
Interesting that both 90 & 110 use the same rear shafts now.... have the 90 ones been made stronger, or have the 110 ones been made weaker Shocked Shocked Shocked
Or have the averaged out the strength, so the 110's might break, and the 90 ones are only slightly stronger Rolling with laughter Rolling with laughter
Post #17631 2nd Nov 2009 7:41am
MK
Have seen the TOB500030-20 from 49 to 212 quid. So I guess they are just the same std LR parts. Puma 110" SW
Post #17722 2nd Nov 2009 11:31pm
jst
£225 for a pair of Ashcroft shafts Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #18243 12th Nov 2009 5:58pm
MK
I was quoted 300. Same price on his web site Puma 110" SW
Post #18263 12th Nov 2009 10:52pm
jst
Sorry i was quoting an old price, my mistake Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #18289 13th Nov 2009 11:15am
ashtrans
Site Sponsor
Hi,
the 90 and post salisbury 110 shafts ate £ 260/pr + VAT,
the Salisbury's are £ 300/pr + VAT Dave
Post #18347 14th Nov 2009 1:00pm
3WHouse
off:
Dave, Hi!!
You can depress the bottom number and raise the top number? (RP 4.1)
Kickdown of the bottom numbers is especially interesting (the analogue is necessary Max-drive) Def`s 90 & 110 Monochrome.
Post #18746 22nd Nov 2009 7:31pm
ashtrans
Site Sponsor
3WHouse wrote:
off:
Dave, Hi!!
Hi,
sorry not sure what you mean, please elaborate,
Dave Dave
Post #19498 5th Dec 2009 8:18am
ashtrans wrote:
3WHouse wrote:
off:
Dave, Hi!!
Hi,
Dave
Morning Dave.
I get the impression this was translated on a website, and i think it's referring to "can the ratio be changed, from 4.1 to 3.54 or 3.2 maybe?" (raising and lowering of the top & bottom numbers Question Question )
Post #19499 5th Dec 2009 8:22am
ashtrans
Site Sponsor
Hi,
yes we do the 4.1 ratio gears for the 90 and the 110 rear, Dave
Post #19546 6th Dec 2009 9:48am
