![]() | Home > Maintenance & Modifications > X-Tech Leak |
Went out today in the torrential rain, looked in the back and it was full of water. Can't be coming up through the tie downs or wheelarches and I had sealed the tub to side panels so thought at first it must be the roof. Anyway I removed the two rear speaker trims and found it sodden, all wiring and speakers soaked through
![]() You can see the water marks here ![]() Looks like its getting sucked up the capping outside and into the rear. You can just see in the corner there is quite a gap. You can see how far the capping is away from the body. ![]() Sealed up outside and in with gutter sealant On the other side you can see there is a hole under the coloured wiring, normally a connector block mounts into this. ![]() Here you can see where I filled up under the capping ![]() 110 HCPU Tipper |
THey all do that sir
Mine has not leaked in this rain ![]() |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
It's indoors Ken
![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Andy Jeff Member Since: 11 Nov 2012 Location: Suffolk, UK. Posts: 143 ![]() ![]() ![]() |
The only manufacturer to do a water ingress manual
![]() Andy. |
Argh but it was outside today as the Lambo was on the ramp again
Putting the Mud Tyres back on Ken
No winters actually
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Nor mine ![]() Main Brian James Trailer Dealer for South West UK |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2673 ![]() ![]() |
Mine did , hence it was chopped in for a D3. No more leaks for me
![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
that you can see at least ![]() 2011MY 110 XS USW Black |
