Home > My Defender > 110 X-Tech Grey Update |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20546 |
Pictures Ken KEEP CALM AND Drill ON 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
8th Nov 2012 5:54pm |
Has Killer been at your centre dash ?
8th Nov 2012 6:25pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
come standard in a xtech much like the Ice Steve CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
8th Nov 2012 6:32pm |
Mr B Member Since: 10 Jul 2012 Location: Buckinghamshire Posts: 33 |
Hey Ken, Great looking truck you have - can I ask where you got the rear carpet from? Presume it's not stock landrover as it runs up the inside panels. Looks great. Thanks Nath |
8th Nov 2012 11:06pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Side Panels (Where windows could be) tge-defendertrims with Dynamat behind
Floor & Wheel boxes Dynamat Extreme then OEM carpets Lower side panels Acoustic carpet |
9th Nov 2012 5:33am |
are you sure Chris?, the pics at the beginning of the thread looks like the dash is black |
9th Nov 2012 8:29am |
Just the Flash the Centre is Grey (Standard XTech)
9th Nov 2012 9:21am |
Well the test fit for the ICE has gone well
Fitting the KIV-700 HU with all the extra RCA’s was fun and it’s going to have to come out again for the light bar install As per the old Utility the rear cargo area has be sound proofed a bit different this time as I reverted back to the trusted Dynamat (seems to be making a comeback) The method I employed was the floor and rear wheel arches are fully matted and the side panels (where the CW’s have glass) have 12 x 12 panels applied (enough to stiffen the panel) The sides and Floor are now trimmed in sound deadening carpet The OEM 10cm has at the front Focal 100KRS with the tweeters being replaced as part of the kit and the crossover being hidden behind the dash (gotta love black tack) The rear apertures currently have “theloudest.co.uk” 300w 10cm co-axail units (these will be replaced with Focals in time Also in the Back is a Focal Active Bomb & an Alpine 2ch Amp to Power the Rear RCA 6x9 TL2691’s in separate enclosures Each Amp has a separate power feed The initial set up sounds good will improve with a Focal upgrade Now to route cables neatly A point to note correct sound proofing will keep the sound in unlike the Essex Gary boys corsa’s Pics when completed |
21st Nov 2012 7:03am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
You're getting good at these write ups Ken
Two questions, do you rate the Focal 10cm speakers over the Loudness ones as I'm about to sort the front out and which brand / supplier did you use for the acoustic carpet please ? |
21st Nov 2012 7:19am |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
I had a sneak audition yesterday, halfway through the installation,and it sounds and looks gooooood!
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
21st Nov 2012 7:46am |
Matt
Focal gives a Crisp Hi and Mid so great if you supplement with a Sub if no Sub then Loudest are suitable Carpet from Car Audio Direct no real reason other than it was in stock |
21st Nov 2012 7:55am |
Thanks Ken,
At the 'back end' I was thinking of the Loudness 6x9 Component speakers (TL2691) run from one of their 4 channel amps bridged (TL2904) with a Kenwood KSC SW01 150watt 'powered sub' - at the front end I was going to go for the Loudness 4" components but now I'm undecided ... Now you've seen the rest of my proposed set up would you still go for the Focal at the front ? |
21st Nov 2012 9:31am |
TBH The Focal Tweeters at the front with the 10cm speakers make it for me
But sound stages are very personal I feel |
21st Nov 2012 9:51am |
Thanks Ken
21st Nov 2012 11:29am |
