Home > Maintenance & Modifications > Anyone fitted a sub under the centre cubby box? |
The carpet was all glued down last year but has come away due to the boot-rubbing
I made the cubby for hiding netbook/camera etc when travelling - very useful and impossible to see from outside. It actually looked quite tidy when new - the photos make it look sh*t (you would never realise it was there, even when you're inside Good idea about the riveting though - I riveted everything else so I was daft not to fix the frame the same way I already have black rivets, so it's a good mini project for the weekend Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
16th Nov 2012 6:51am |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
I fitted mine behind the front passenger seat as the bulkhead allows for the space.
Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
16th Nov 2012 12:06pm |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
i have a Kicker TCVT8
fits nicely under the cubby inclined (its wedge shaped anyway) with opening to the front it makes your bass come from the front and not from the back. so keeps the sound image together. Not a hip hop dominant boom box but with the A class amp and bose speakers goes up to "unbearable" levels without distortion. very happy with it |
16th Nov 2012 2:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20408 |
good choice with the kicker. what power is it RMS may i ask. $W33T $0U7H3RN $UG4R
16th Nov 2012 3:53pm |
As per your instructions Sir:
Before Click image to enlarge After Click image to enlarge :) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
19th Nov 2012 3:37pm |
That looks much better Mattilda. Well done.
Honestly though it does. It would have got worse too the carpet over time and frayed more. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
19th Nov 2012 3:48pm |
My friends call me Maggie... Tell someone you love them today because life is short.
19th Nov 2012 3:52pm |
I'm sure they do. I assume that trim is anodised black is it or painted? $W33T $0U7H3RN $UG4R
19th Nov 2012 3:55pm |
Steve,
It's the 8", 200WRMS 4 Ohm Driven by a 4x80W RMS SIGNAT class A amp (Bridged for SW so 160) |
19th Nov 2012 4:22pm |
Tatra - Mines 8" too but the square one instead and a bit more powerful so needs more space but yours as you mentioned will fit in more awkward areas. It can be difficult to get a happy medium between power and size. $W33T $0U7H3RN $UG4R
19th Nov 2012 4:26pm |
It's anodised aluminium profile (what do you call that in English?) but I could only get silver or brown (yeuch). Bought silver and painted it black - still, a wipe over with thinners and the paint stuck really well. In any case, the ridge effect will look good if/when the high points wear off Cheers Marge p.s. Doh - "Profile" is obviously called "trim" Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
19th Nov 2012 6:10pm |
Alu anodised trim yes. Ideally you want acid etch primer then the base then lacquer. but that costs plenty for a small job. $W33T $0U7H3RN $UG4R
19th Nov 2012 6:53pm |
Just realised - photos 3 months apart and I'm still wearing the same jeans Tell someone you love them today because life is short.
19th Nov 2012 7:47pm |
