Home > Maintenance & Modifications > Defender 130 - rear seat box question
Any reason why I can't form a lid in the rear seat box of my Puma 130 ?
My Td5 130 has a lid and is great for storage but the Puma is a one piece box with no opening, is there a reason why ?
Post #186103 18th Nov 2012 5:13pm
SGH
Don't know but why not cut a hole in your one first then if it's OK I can do mine. :rolllaugh:
Post #186104 18th Nov 2012 5:15pm
Excellent reply Rolling with laughter
I'm guessing it was easier for Land Rover to not cut a hole as there are the additional brackets for the new rear seats, can't see why it wouldn't be ok, may need a little bracing that's all
Post #186108 18th Nov 2012 5:18pm
SGH
If you look there are stiffeners you can see the spot welds so it might only give a small storage area. I was going to fit the lock box you supplied under seat but would not go in between spot welds so decided not to cut it open.
Post #186109 18th Nov 2012 5:21pm
In which case, it is my duty as a supplier of (British made) parts to investigate this for you and report back Mr. Green
Post #186112 18th Nov 2012 5:26pm
SGH
I've fitted it in nearside floor plate now.
Post #186115 18th Nov 2012 5:28pm
Ahh, OK.
Well, I'm going to investigate anyway as I want to fit a Viair twin compressor and air tank in there
Post #186117 18th Nov 2012 5:30pm
SGH
Fitted ARB twin under 40 seat fits a treat.
Post #186123 18th Nov 2012 5:35pm
Yes, I saw picture, looks good !
I've had a look and there just isn't room for my set up unfortunately
Post #186127 18th Nov 2012 5:42pm
AndrewS
Why not sink a box into the floor between the chassis.
 130's have feeling's as well you know Smile
Post #186185 18th Nov 2012 8:13pm
Hi Andrew, I presume that is set into the floor under where the seat box is sited ?
So, no reason not to do the same thing in the top of the seat box ?
Post #186189 18th Nov 2012 8:34pm
AndrewS
Yes and Yes you could Thumbs Up 130's have feeling's as well you know Smile
Post #186193 18th Nov 2012 8:50pm
Excellent
Thank you Thumbs Up
Post #186194 18th Nov 2012 8:53pm
