Home > Tdi > 300tdi temp gauge |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
That doesn't sound all that normal, my 200tdi one sits nicely in the middle all the time and heaters work quite well.
I did have some similar symptoms on mine a few years ago and it was sorted out by replacing the engine earth strap, not quite sure what that has to do with it but it fixed the issue, so might be worth checking you have a decent earth. No doubt someone who knows what they are talking about will be along in a bit. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
16th Nov 2012 5:48pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2659 |
Normal operation for a Defender temperature gauge (at least up to and including Td5 models - can't speak for Tdci) is for it to rise to half-way (or just under) and stay there.
Earth is a good shout, but the heater issue is more worrying. Are you losing coolant? |
16th Nov 2012 6:06pm |
DavidJewiss Member Since: 05 Nov 2012 Location: Essex Posts: 11 |
I don't think so, I'll have to have a proper check tomorrow in the daylight. I wouldn't be surprised if the heater was just due to controls not working properly as I was playing about with them a bit where I haven't had it long, today was the only time I've driven it long enough to get any heat at all!
I'll have a look at the earth strap tomorrow too as its it's too dark now, the car has a 3 month warranty as I bought it from a dealer but if its a simple fix I'd rather just do it myself, failing that Ill have to take it back but I wanted to be sure that it wasn't normal. How often should the engine be getting hot enough for the fan to kick in? |
16th Nov 2012 6:36pm |
Unfortunately I can't answer that one! A thermostatic fan is not a standard fitment, so it depends what temperature the thermostat is set to. When I used to have a thermostatic fan (using an X-Engineering X-fan controller), it never used to come on under normal working conditions. Pulling a big trailer up a steep track would see it on, but it never triggered during normal driving where there was good airflow over the radiator. |
16th Nov 2012 7:17pm |
IKke Member Since: 16 Aug 2008 Location: Brabant Posts: 117 |
My 200tdi takes a while to move to the center and if it doesn't have to work much and I put the heater on full blast it will go down to about a kwarter And it has an electric fan which is always off in these temperatures. Scaling the real deal.
17th Nov 2012 1:14pm |
