Home > Maintenance & Modifications > X tech rear led indicators install....need help
mcma1
So I have have these from mud but wondered what way these are installed??
Is is a matter of joining the green on the loading module and the green on the light and then into the connector? And the same for the white?
Also what is the order to put these connectors together?? What are the green rubber bits for??
Andy
Post #185397 15th Nov 2012 9:31pm
mobilecentre
Send them to me and I will put them together for you FOC.
Mobile Centre - F.A.O. Tim
PO Box 222
Evesham
WR11 4WT
Post #185399 15th Nov 2012 9:32pm
mobilecentre
Do not bother trying to put the plugs on yourself as they have not even supplied the correct ones you need.
Post #185401 15th Nov 2012 9:34pm
mcma1
Cheers Tim,
I will send them tomorrow. Can you take Saturday delivery?
Post #185402 15th Nov 2012 9:37pm
mobilecentre
95mm rear lamps buying guide for anyone thinking of getting any - ours all come with the correct connectors pre fitted Thumbs Up
http://www.defender2.net/forum/topic16405.html
Post #185406 15th Nov 2012 9:43pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
[quote="mobilecentre"]Send them to me and I will put them together for you FOC.
If Carling made LED lighting specialist they would be like Mobile Centre
Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #185428 15th Nov 2012 10:07pm
mcma1
Case closed.... All under control now thanks to Tim! Cool
Post #185433 15th Nov 2012 10:12pm
That is how customer service should be !
Congratulations Tim Bow down
Post #185437 15th Nov 2012 10:14pm
