Home > Td5 > TD5 Fuel pressure test |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 153 |
Did the gauze filter fall out when u changed the reg or has any got in the fuel system is there any smoke
Phil |
15th Nov 2012 9:28pm |
AlexLandy10 Member Since: 03 Nov 2012 Location: Ipswich Posts: 15 |
i took the gauze filter out to check/clean it, i remember putting it back but it could of fell out i suppose, can i remove the regulator to check and just fit a new gasket and o ring or is it a new regulator aswell, the fuel filter has been changed and it doesnt appear to smoke any worse than any other td5. If at first you don't succeed, hit it harder or get someone else to do it.
15th Nov 2012 10:54pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
When I first fitted the custom pump/filter system to Pam's I used a standard oil pressure sender/gauge as they are a LOT cheaper than fuel pressure gauges for some reason. Worked well and helped diagnose the problem we were having at the time.
I temporarily fitted an inline T gauge adaptor for it between the pump and the regulator, next to the regulator. http://www.yorkshireoffroadclub.net/ |
15th Nov 2012 11:25pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
Hi Alex,
I made one, used the old prv block pipes and a -6 fitting. The threads were different but close enough with ptfe tape. http://www.defender2.net/forum/post186485.html#186485 Steve |
19th Nov 2012 10:17pm |
28th Nov 2012 12:57pm |
Steve B, good thinking on trying another one, if it makes a difference then great, if not i can always re sell the new one, ive ran injector cleaner through it, its not been on a nanocom, just hawkeye and only faults were things not fitted like ABS and EGR which has long gone. Thinking about it, its only since fitting a new regulator it started so why have i not thought to change it before in case the replacement (genuine) was faulty. If at first you don't succeed, hit it harder or get someone else to do it.
28th Nov 2012 6:46pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Yes.... Me I can plug my pressure gauge in and have a look. I'm just on the outskirts of Tamworth, so not a million miles away. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
28th Nov 2012 7:05pm |
i think i might take you up on that offer prior to just trying a new regulator, im sure it would be cheaper to test it first, just need to get of work for a few hours now, hmm If at first you don't succeed, hit it harder or get someone else to do it.
28th Nov 2012 7:55pm |
