Home > Technical > Speedocruise for new Defender? |
Herman Member Since: 14 Jun 2007 Location: Walvis Bay, Namibia Posts: 3 |
Is it possible to fit the Defender II cruise control?
8th Feb 2008 5:55am |
rick Member Since: 07 Mar 2008 Location: Perth Posts: 133 |
I can't find anything on this either - there seem to be quite a few aftermarket kits available but nothing I would trust. Let me know if you find something.
Cheers, Rick. 1998 RR HSE 2007 RRS TDV6 2008 Defender 110 2015 Discovery Sport |
10th Apr 2008 1:25am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
i looked at this and cant find anything. The td5 method wont work and the puma ecu is not the same as disco, rrs etc Mike
10th Apr 2008 6:29am |
Petrovich Member Since: 24 Jan 2008 Location: Sankt-Peterburg Posts: 75 |
Found this one in Germany http://nakatanenga-tours.de/shop/article_TEMP4DE/Tempomat-für-Land-Rover-Defender-Td4-MY07.html?shop_param=cid%3D24%26aid%3DTEMP4DE%26 Transleted by Opera automatically High-quality more eschwindigkeitsregler, fitting for all Defender Td4 starting from MY07. Simple and comfortable use. More easily installation by our fitting instruction. The elegant comfort speed governor! Comfort: The distance automatically the speed regulates long travels without effort and stress, the speed governor. It cannot occur any longer the fact that you exceed beyond that inadvertently the speed limit and is a fuel economy required. Security: The switched on speed governor leaves the vehicle price increase further to the driver. For accelerating, simply like normally gas give, for slower driving normally brake, the speed governor switches off automatically. The speed governor is really practical. With a simple click the speed programmed before again one takes up. Gladly we build the automatic controller also in our workshop. But a time requirement of approximately 4-5 hours as well as a lump sum of EUR 200 result, -. Dispatch weight 1.00 kg Defender 110 '07 |
10th Apr 2008 9:27am |
Thanks Petrovich - you've given us hope.
10th Apr 2008 12:41pm |
Yeeep! But For Td5 - cost !!! Its really enoing Defender 110 '07 |
10th Apr 2008 1:38pm |
And can look like its suppose to be there Mike
10th Apr 2008 4:01pm |
igorescobar Member Since: 26 May 2008 Location: Pau Posts: 4 |
Have any of you guys fitted one of these cruise control things to a PUMA?
28th Aug 2008 11:07am |
I have also found this guys in the UK who seem to be selling the same type of cruise control but about 60 quids cheaper....
http://www.howard-may.co.uk/ |
28th Aug 2008 12:27pm |
