Home > Maintenance & Modifications > CD's skipping when I turn up the volume...why?
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I have a recent CD/iPod compatible Kenwood head-unit installed and connected up to a new Alpine sub (with built in amp). It all works fine except that when I turn the volume up to a decent level the CD starts to skip as if it's scratched. Turn it back down and its fine again. When I listen to the radio or iPod at any volume it's fine.
Any ideas why? Is the Kenwood not up to the job ? Earth not good enough on the sub? Cheers,
Superspoons
Post #185139 14th Nov 2012 9:19pm
Laurie
Too much bass? Rolling Eyes
Post #185141 14th Nov 2012 9:32pm
AndyS
Transport is fudged, take the head unit back.
Post #185144 14th Nov 2012 9:42pm
superspoons
Could be.... I do like to belt out a bit of The Cult now and then Laughing Cheers,
Superspoons
Post #185145 14th Nov 2012 9:43pm
superspoons
It's about 2 years old now (used to be in my TD5)... looks like a good excuse to get a new unit Smile Cheers. Cheers,
Superspoons
Post #185146 14th Nov 2012 9:47pm
If it was bass vibration then the CD would skip when driving over a rough surface too. If it doesn't it's not that. Try it without the sub and see if it does then or not if it still does it'll likely be the HU laser misreading or something electronic malfunctioning inside. $W33T $0U7H3RN $UG4R
Post #185166 14th Nov 2012 10:20pm
AndyS
My home system kicks out enough bass to shake the front door and the CD player just chugs along fine, it ought to be able to handle some bass (imagine the demonstrator cars at JBL etc, they'd be fudged if the CD player couldn't handle a bit of bass).
My Smart had a skipping problem with the CD player, I took it back and they replaced the transport.
Post #185171 14th Nov 2012 10:26pm
What is that exactly?
I also never use CD's in mine only iPod / radio because CD's and Defenders don't mix very well IMHO. Especially with the state of the roads. Rolling Eyes $W33T $0U7H3RN $UG4R
Post #185174 14th Nov 2012 10:30pm
superspoons
I think one of these will do nicely...
http://www.kenwood-electronics.co.uk/produ...DC-BT92SD/ Cheers,
Superspoons
Post #185176 14th Nov 2012 10:35pm
I would recommend it. Then again I am biased. Whistle You'll also be able to have green illumination too that will match the dash.
Thumbs Up $W33T $0U7H3RN $UG4R
Post #185178 14th Nov 2012 10:38pm
AndyS
A CD transport is the actual mechanism that holds the CD and laser in position while the magic is happening, the guts of the system if you like. If it's skipping then we can assume the laser is loosing position on the CD by either the laser loosing it's tracking position or the CD moving, either way it's the transport that's to blame.
When you get into it, you'll find a lot of systems from different manufacturers us the same CD transport but add their own electronics to it to produce their own sound.
Post #185184 14th Nov 2012 10:44pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
This isn't one of those head units where you can set the peak voltage level for the sub output, or the impedance match with a switch on the back is it? If it is, you may be driving it too hard and causing HU PSU output voltage to partially collapse, hence upsetting the CD transport.
This may also be configurable in one of the settings menus.
Pete
Post #185187 14th Nov 2012 10:51pm
superspoons
I've been through the settings and switched the Sub off via the menu on the unit - a Kenwood KDC-4547U - still skips through the CD when the volume is turned up. Can't find anything on the unit or in the manual to switch off / do.... Think it's a trip to Halfrauds/Eblag for me Sad
Manual is here if anyone can point me to a feature... -
http://manual.kenwood.com/files/4acea7a1a4efd.pdf Cheers,
Superspoons
Post #185320 15th Nov 2012 6:46pm
Can't see anything that would cause it in the manual. I would exchange it as it shouldn't do it. Regardless of where purchased from would record a video / sound recording of the actual CD skipping happening too. That way you have back up proof to show that it is doing what it has been. otherwise they might just try and fob you off and say the volume is probably too high. $W33T $0U7H3RN $UG4R
Post #185322 15th Nov 2012 6:53pm
superspoons
Cheers for taking the time to look Steve. I'll try and find the receipt from Halfords and pop it back...I think it's a good 2+ years old now though...not sure how receptive they will be. Cheers,
Superspoons
Post #185333 15th Nov 2012 7:23pm
