Home > Maintenance & Modifications > Anyone fitted any noise insulation on their Puma?
discocuzzy
Fitted a noise killer kit on the old TD5 and it made a hell of a difference, anyone fitted anything to their pumas?.
To be honest i cant be arsed to fit another one so wanted to know if anyone had one fitted and if any other brands were available?
Doing loads of road miles at the moment so its going on all terrrains as well. You cannot teach stupid people to do clever things
Post #18428 16th Nov 2009 8:30pm
110SEB
IMHO the road surfaces in this country are shocking. Who ever thought those beige sections that make up the road surface on crap roads were a good idea. The idea of having a conversation goes out of the window in any car.
Give me the A6 from Calais to Reims in France any day. It is the best made motorway I have ever been on. It helps that it's always empty and my usual M-way is the M25.
Old man moan over Thumbs Up
Post #18434 16th Nov 2009 9:00pm
AndrewS
I got some sound proof paint that Ive not used yet.
The most un helpful post of the day award goes to me Thumbs Up
Post #18435 16th Nov 2009 9:17pm
discocuzzy
Rolling with laughter Rolling with laughter Rolling with laughter a simple no would sufice Andrew!! Thumbs Up
Seb...go and sit in the corner for not answering correctly! You cannot teach stupid people to do clever things
Post #18437 16th Nov 2009 9:51pm
carpenpa
England 2008 Defender 90 Puma 2.4 XS CSW Cairns Blue
Half hearted attempt - half success
I bought some adhesive vibration damping material (the sort used by ICE installers) and stuck this to the sides of the driver and passenger seat bases (there is not room for anything thick between the seat base and the door). I put some thick foam underlay under the carpets under the front seats and cubby box and lining the driver and passenger footwells. Finally I laid the same underlay to cover the floor and sides in the back (only where covered by carpet).
Overall a cheap exercise and only slightly successful. It is impossible to judge sound deadening without optimistic bias unless using proper equipment. What I really wanted to dampen was the noise from the engine. I suspect that under-bonnet sound proofing and enhancement to the firewall layer (which would be virtually impossible) would be more effective.
Rolling Eyes Rolling Eyes Thoroughly enjoying my landrovers in the far west.
Post #18449 16th Nov 2009 10:29pm
110SEB
I don't want to dampen (geddit?) anyone's hopes, but the more insulation there is up front, the more water is held against the metal to speed up corrosion.
What happens under rubber mats can stay there for ages until you lift them and inspect. Most of the time you'd never know that your carpets are sodden. Check them regularly and get them in the airing cupboard Thumbs Up
Post #18462 17th Nov 2009 8:23am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
If you think your roads are crap, come down this way for a holiday Rolling Eyes
UK roads are sooo much better.
As for noise. The best thing I've found is to have the back of the Puma full of camping gear to the back of the front seats. I'm more concerned about putting a heat shield over the transfer case so I can use my under cubby strong box. It gets so hot you could use it to cook in.
I actually don't find the Puma that noisy. I suppose because I drive a Tdi 110 every day - wife gets the Puma as daily driver Sad 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #18463 17th Nov 2009 8:36am
spudfan
Ireland
I second the above post. Just driven the 110 200 tdi this morning. Compared to that the Puma is whisper quiet. I do not think the Puma needs additional sound proofing. If you are not convinced start up and drive a series 111 diesel or a 200 tdi on a cold morning! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #18471 17th Nov 2009 11:50am
Grockle
pardon Laughing 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #18473 17th Nov 2009 1:07pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Yes the Puma is heck of a lot quieter than my old Turbo Diesel 90 Very Happy
But i do find the hard top "drums" at speed, so i am thinking of ply lining the sides with some form of insulation (foam?) between this and the Hard Top sides.
I'm already in the middle of fitting ply on the wheel boxes. It is already all cut to size and is in the garage being varnished at present. When fitted I will also be gluing rubber matting to it which should reduce road noise from below. MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #18475 17th Nov 2009 1:57pm
spudfan
Ireland
Try a roll mat that you use for sleeping out on. It can be cut and fitted to the hardtop sides or cut and fitted beneath the footwell trim. It can also be cut and stuck to the inside of the seat boxes. Cheap, waterproof and does the job. 1982 88" 2.25 diesel
Post #18479 17th Nov 2009 2:58pm
discocuzzy
I guess i am comparing it to a disco 3 Whistle , on the phone a lot with work whilst driving and usually have to slow down to under 60 to hear the call Big Cry
Im guessing my mud terrains arnt helping either Thumbs Up You cannot teach stupid people to do clever things
Post #18490 17th Nov 2009 7:09pm
spudfan
Ireland
Points taken.
I don't have a mobile phone.
I am still running on General Grabbers.
I have to drive 12 miles to find a road that I can legally do 60 mph on.
I still say it is a (relatively) quiet vehicle . My series 111 diesel would need to be stopped with the engine turned off in order for someone to use a mobile phone! Very Happy 1982 88" 2.25 diesel
Post #18494 17th Nov 2009 7:41pm
discocuzzy
Thumbs Up 10k since June in mine Shocked , no phone Shocked Shocked it would be like having my arms chopped off spud! You cannot teach stupid people to do clever things
Post #18496 17th Nov 2009 8:06pm
MUF
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Aluminum Chequer Plate Liner:
http://www.njaluminiumlinings.co.uk/land-r...16268.html
Quiet as a mouse! Bow down Love in this order; Burnley FC, Defender, Kids, Wife, LOL
Post #18501 17th Nov 2009 9:45pm
