Home > Puma (Tdci) > LED front indicator lights for the SVX style grill
dgardel
Italy
Another Outback Engineering goal!!!!
Original from Hella, now I'm 100% fulle LED!!!! and, like our LED, homologated!!!!
Wil post photos when installed
for more info see my partners links (Mobile Centre)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #184359 12th Nov 2012 5:18pm
Should look good. Thumbs Up $W33T $0U7H3RN $UG4R
Post #184360 12th Nov 2012 5:19pm
will these replace the 90mm spots ?
Post #184370 12th Nov 2012 5:58pm
Killer90
Site Sponsor
Thumbs Up Thumbs Up these are going to look the Dog 's CSK Automotive
www.cskautomotive.co.uk
Post #184373 12th Nov 2012 6:08pm
dgardel
Italy
no, the 50mm front indicator
IID Pro MV License
Post #184386 12th Nov 2012 6:22pm
dgardel
Italy
Arghhhh I'm not at 100% LED!!!!!!!!!!!!
Tiiiimmmmmmm help me Rolling with laughter Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #184388 12th Nov 2012 6:23pm
ericvv
Afraid Tiiiiimmmmmm has no ready made solution for replacing the 90 mm aux by LEDs right now. Tried him on that already a good week ago, but no plug and play solution apparently Big Cry
Also still waiting for offers for the Perei LED number plate light which seems like a first class identical LED lamp as the standard one. Tim has apparently got hold of one of those which he is testing on a Defender..... Question Question Question You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #184402 12th Nov 2012 6:49pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
DG, have you changed the flasher relay to accommodate these too? If so, have you lost the trailer indicator repeater in the dash now?
Pete
Post #184495 12th Nov 2012 10:34pm
dgardel
Italy
Pete
Yes because I have the JW Speaker rear led set also. No problem about the trailer indicator repeter.....
No trailer at all Mr. Green Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #184498 12th Nov 2012 10:38pm
mobilecentre
We used to have two Defenders at the minute we have none so testing is taking a while!
I have offered it up and it all looks good - I do not have the plugs so it will be a cut and shut with the original if you want to fit it.
Post #184680 13th Nov 2012 4:04pm
mobilecentre
I have ordered some SVX driving lights - which I will be selling soon when I have figured out a mounting strategy Thumbs Up
Post #184689 13th Nov 2012 4:18pm
mobilecentre
We have been on the case for a while but I have had some time off and we currently have a lack of test vehicles to do any development on.
Post #184690 13th Nov 2012 4:19pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
[quote
We have been on the case for a while but I have had some time off and we currently have a lack of test vehicles to do any development on.[/quote]
i'm building her has quick i as i can..... Putting Dreams on Drives at JLR Solihull..
Post #184771 13th Nov 2012 7:26pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Get your finger out Ada , what you doing on here when you could be rebuilding the Defender. Rolling with laughter
Post #184775 13th Nov 2012 7:32pm
mobilecentre
It would not suprise me if Betty was finished first!
Post #184776 13th Nov 2012 7:33pm
