Home > Maintenance & Modifications > Which cubby box replacement.
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Want to replace mine with one that is higher for a better armrest, bigger for more stuff and lockable. Is there a make which stands out above the rest?
Post #184262 12th Nov 2012 9:20am
We offer our fcxRADIOBOX which is on Special offer to forum members at the moment.
We can also cover the lid in our leather and add as much padding as you want.
If the radio section is not required and you can wait a couple of weeks, we are about to launch our standard cubby box that has exactly the same shape / profile but comes without the opening radio section.
Lastly, in the New Year we will have our fcxRadioSwitchbox with an additional switch panel available ...
www.FCX.ME.uk
Post #184265 12th Nov 2012 9:42am
JSG
I've always been very pleased with the ones from Mobile Storage and wouldn't hesitate to recommend them.
In the current 110 I've retained the original but fitted a lockable safe under it. John
2011 Tdci 110 CSW XS
Post #184281 12th Nov 2012 10:55am
Or... Make one to exactly how you want it. Be prepared for some work though if you did. Very Happy TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #184283 12th Nov 2012 11:17am
Thud
Can't be arsed with all that. I'm a prop maker by trade and I like to leave all the work behind when I can I'm ashamed to say.
Post #184284 12th Nov 2012 11:20am
Tim_NZ
Australia
Whistle Here's one I prepared earlier: http://www.aulro.com/afvb/projects-tutoria...panel.html
Post #184286 12th Nov 2012 11:30am
Thud
Now that's not bad at all Tim!
Post #184287 12th Nov 2012 11:32am
Awesome. Similar to what I did. Thumbs Up Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #184290 12th Nov 2012 11:36am
Mine:
I didn't retain the cup holders on mine because I never used them. All I need now is a seal between the cubby and the lid and two types of clamp each side to hold it down secure so it's air tight for the sub. Inside it's all black carpeted. Very Happy
Basically though you would put anything into the front face of it you wanted. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #184291 12th Nov 2012 11:46am
Thud
Shocked
Post #184295 12th Nov 2012 11:59am
leeds
Thud, consider carefully what you want from that space between the seats.
Lots of possibilities out there, just be careful that any box you buy is compatible with the Puma. Some are too long especially with the drink holder and can interfere with the hi low gear lever.
A lot of these boxes require drilling the panel underneath.
Only one company I am aware of does a fixture so no drilling is required.
Ditto only one company does two height of pads, so try and work out the height you require for the pad.
Nakatanenga does a under cubby box security box. One of our customers uses this security box to transport legal class A drugs for medical purposes.
GMB does a similiar box but for putting lots of electric bits in and has a twin voltage display if running two batteries.
So decide exactly what you want, height, ease of fitting, drinks holder etc etc. Then decide what is best suited to your needs.
Both MSS and Safari Equip do good cubby boxes and there will be other makers out there as well.
Brendan
Post #184301 12th Nov 2012 12:17pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Mine:
I always thought your avatar was a cooking ring! Now I know different........ Embarassed Euro-Leafing to infinity and beyond.....
Post #184305 12th Nov 2012 12:38pm
Thud
You probably could boil a pan of water on that thing.
Post #184306 12th Nov 2012 12:40pm
Happyoldgit
Mine:
I can just see that lot filling up with mud, bits of hay, straw, dog hair and bird feathers in mine Rolling with laughter Steve.
http://forums.lr4x4.com
Post #184309 12th Nov 2012 12:52pm
Will Brendan turn up at your house, Thud, with a box for you to try insitu ?
We will ! Rolling with laughter
Post #184313 12th Nov 2012 1:15pm
