Home > Puma (Tdci) > Transmission Leak Advice
JonM
I know Defenders leak… I was hoping someone could help me decipher if the leak was my Defender simply saying hello or asking for help. The leak is somewhere from the transmission, I cannot quite tell from where though. Any ideas?
Post #170891 26th Sep 2012 2:09am
JonM
Post #170892 26th Sep 2012 2:11am
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
Have a look at your gearbox filler plug. You may find that it's blowing by.
Mark
Post #170907 26th Sep 2012 6:09am
skoller
Could be the front drive shaft seal. Mine looked like that even no oil was evident coming from the seal. The dealer changed the seal and all was o/k until the transfer box became rattly and was changed under warrenty.
Post #170908 26th Sep 2012 6:20am
Stephan
Namibia 2008 Defender 130 Puma 2.4 HCPU Alpine White
jon,
Unsure on your model but make sur eyou are using the new oil pan for the engine as hte original one (2008-209) was on the course way of the front axle.
Also i just had my transfert cse sealing conpound on the plate cover that fail. LR dealer recommendation in SA is to use loctight type rather than LF genuine part.
stephan Stephan
Meiring II - 130 Puma 2008
Meiring I - 110 200TDI 1989/1991
Post #171703 28th Sep 2012 10:19pm
JonM
Fixed. It was the transfer case seal. While the part number was correct, the seal I removed was 2mm bigger than the replacement. I am thinking that LR had a bad batch or something.
Thanks everyone
Post #173921 8th Oct 2012 1:55am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Do you have the part number for the seal please?
Thanks,
Mark
Post #183946 11th Nov 2012 8:59am
pope10001
Thanks,
Mark
Post #183949 11th Nov 2012 9:02am
JonM
The part # is ICV100000 and it’s a standard LR part for the transfer case.
Good luck!
Post #184671 13th Nov 2012 2:46pm
pope10001
Thanks, for the part number. Unfortunately my problem has progressed. Upon further investigation and after removing my gearbox protection i was able to see where the leak was coming from. My righthand gearbox rubber mount had snapped which in turn caused my tx box to crack and leak. New Tx box recieved from Ashcroft 2 days ago, which hopefully i will manage to get into the 90 tomorrow. Pics of the damage to follow if i can workout how to get them on here.
Regards,
Mark
Post #186305 19th Nov 2012 1:29pm
