Home > Technical > Puma odometer from miles to km
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
Can the above be done? I can't read miles, it's always km...
Post #183350 9th Nov 2012 12:22am
IFAIK the only way to change to miles is to replace the instrument binnacle, then have LR reprogram it to the ECU
When I imported my truck from CH to GB I replaced the instrument decal because KM or Miles are acceptable for measuring the total distance.
The units do look the same Miles & KMs it's probably just a software change
Post #183365 9th Nov 2012 8:06am
nikojo
Very simple change. I had "opposite" problem.
Ordered new binnacle in MPH. Simple screw driver to remove trim and the binnacle just lifts out and has simple plug in bag.
I've now got an extra binnacle in KM...........don't know how much to ship to Singapore Smile
Post #183740 10th Nov 2012 4:44pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I ordered a left-hand-steering Defender as I do a considerable amount of European travel; in effect Land Rover pulled a Belgian spec one off the line, added a UK spec alarm and other bits to it and sent it to my dealer.
Although it was to be UK registered, I had to scream a bit before they replaced the headlamp lenses for left-hand-dip and swapped the positions of the reversing and rear fog lamps and, more importantly, changed the kmh only speedo to a UK one, i.e. one with both mph and kph markings.
Straightforward physical swap as nikojo says, BUT the dealer experienced quite a bit of trouble matching it up to the electrickery.
My guess is that the choice is between kmh speedo and km trip, or mph/kmh speedo with mph trip.
Peter
Post #183900 10th Nov 2012 11:57pm
ronwong
For me, the word miles is shown in the digital display, it's not a physical print, mine is a 2.2 puma by the way, Si I thought it would be a simple program. If I can use your km display, would really appreciate it, will check with my workshop firsy
Post #183956 11th Nov 2012 10:42am
TfredJ
New Zealand 2010 Defender 130 Puma 2.4 HCPU Alaska White
I know it has been a while since your post, did you have to have the new binnacle programmed to the Landy ECU, I have had conflicting info on this. I want to swap a UK MPH/KPH unit to a KPH unit with odometer in KPH.
Post #549722 19th Jul 2016 12:57pm
integrale
New Zealand
TfredJ I have a brand new KPH unit available. PM me if you are interested.
Post #549860 19th Jul 2016 9:25pm
