![]() | Home > Puma (Tdci) > OLD QUESTION |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 ![]() ![]() ![]() |
On my Poogot van I had a similar thing happen from time to time. I was in a bit of a pickle because the dealer had closed down so nowhere to take it (without a bit of egg on my face because I chose the now defunct dealer over the more established). Long story short, a friend gave me a way of resetting the ECU to clear the faults. It was a long and weird process, wind the window down, dis-connect the battery and re-connect after 60 seconds, open the door three times, indicate left etc etc.
It did work, the ECU reset procedure would kick in and the central locking would activate several times to acknowledge completion and that'd be the end of it for several months. Is there a way of resetting the ECU on a Defender? |
Ultra Gauge - £60 ish ... OBDCII reader should do the trick
Gil9713 Member Since: 11 Sep 2011 Location: Colchester Posts: 94 ![]() ![]() |
Thanks for that. I bought a COBRA handheld analyser off Ideal World a couple of months ago. A very simple bright yellow handheld device with a lead terminating to a scart. With it was a booklet with all the likely codes that could be encountered from an ECU.
Anyway cut a long story short, the Land Rover dealership, said not to clear down the fault, using that or any other garage. Well the reason I bought it was exactly that. Before they changed the fuel rail and gave me happier motoring, I had to take it into A N OTHER garage who proudly charged me £40 for the privilege of clearing it down. Thats the main reason I bought the COBRA device for £36. They come up fairly regularly and I think they advertise them on their website, good bit of kit, but of course not on my truck when I needed it. I also understand, when this Amber warning light occurs, if you stop/start the engine three times, it clears the light but leaves the fault on the ECU. Is that correct or am I being fed a pup? Otherwise the first thing in the morning I will stick the scart into the old girl and see where she's ailing, and decide what to do then!!(under warrantee) and back to the "experts" I suspect. |
