- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
RED-DOT
My November 2007 90 CSW is in at my local dealer for the following repairs... Propshaft to be renewed as it came with no grease nipples. Front grille to be replaced or repainted due to the two mesh inserts losing the paint. Headlight bezels replaced. Drivers seat base to be replaced due to no springing in the seat. Gears crunch in 2nd and 3rd and they say they will lubricate. ECU upgrade to be done. Vacuum pump failed at the weeked and the spotless engine compartment now looks like a coal lorry. Stereo loses preset when ignition is turned off and searches and locks on to the frequency with the loudest hiss. Bonnet touching the wingtops and apparently there is no adjustment but they will "drop" the wings. Rear crossmember to be repainted as it has faded badly.
PS has anyone had the stereo fix done and what did they do?? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
10th Nov 2009 8:55am |
Ninetenths
Had one relay fail in 2 years and 30k miles Pimped black '07 Puma
Equally Pimped Black Pick up Truck
Rollin deep
14th Nov 2009 9:43am |
fekete
They just put a new stereo in mine NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
14th Nov 2009 9:59am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
