Home > Maintenance & Modifications > Rear folding step woes
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Hi All
On Saturday as I was loading the 110 with the new bathroom the rear step gave a sickening lunge.
On further inspection I found one of the rivnuts had finally pulled through the cross member leaving the second somewhat precarious.
As this is quite a common problem I was wondering if anyone, possibly the sponsors, have any reaffixing suggestions.
The step is frequently used as a launch pad up the ladder to the roofrack for loading etc.
Please no funnies about losing weight, I get that ALL the time from the other side of the bed Rolling with laughter
Bellow are a couple of shots of the state of the cross member.
The stretched hole: Hmm looks like I need to do some rust fixing too.
General shot:
The remaining but compromised rivnut:
 He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #182192 5th Nov 2012 9:29am
mk1collector
Just use nuts and nylon bolts with good sized washers, that's what I did Thumbs Up
Post #182218 5th Nov 2012 11:33am
Eduardo
Similar problem and same solution...
Finally as mk1collector do. I replace the rivnuts by a bolt with a nylock nut with good washers.
No problem since (3 years)
Cheers Eduardo
Post #182231 5th Nov 2012 12:09pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
There is a TSB about this and a fixing kit available from Land Rover to fit behind inside the cross member. I bought this fixing kit to fit my secondhand step before I damaged the cross member.
I think the part number is LKVL500240 and cost me £39.38 +VAT. Quite expensive, but it would have taken me ages to faff about getting the right sized bits and bobs and it included all the necessary fittings that didn't come with my secondhand step.
I think I downloaded the TSB. I'll try and remember to post it when I get home so you can see the detail.
Post #182235 5th Nov 2012 12:35pm
mk1collector
Wow Shocked that's a hefty price when a couple of bolts, nuts and washers are about 3 or 4 quid!
Post #182252 5th Nov 2012 1:07pm
df1
As stated above, I just got a couple of m10 bolts, lock nuts and big flat washers. Job done, couple of euro and a few minutes.
Post #182261 5th Nov 2012 1:37pm
megatoad
I did see while trawling previous posts a reference to a LR Fix thanks Inigo, what did it consist of?
As for the general repair method suggested by all you other grand defender folk, how did you get into the cross member to hold the nuts while doing it up?
Julian He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #182268 5th Nov 2012 1:53pm
mk1collector
There are holes all over the place in the cross member but a bit of contortionism helps Mr. Green
Post #182333 5th Nov 2012 5:08pm
megatoad
Getting too old for that, taken week off for replacing the fecking bathroom at the moment money money money Big Cry He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #182344 5th Nov 2012 5:40pm
Inigo
Link to PDF here:
[img]https://www.defender2.net/gallery/albums/userpics/12439/LD501-007V2%20Rear%20Step%20Loose.pdf[/img]
It shows shaped bits of metal welded to nuts so that they do not rotate. Also suggests which way to shove your hand to hold your nuts (as it were).
Depending on the age of your vehicle, it could have been considered a warranty item from reading the bulletin. Might be worth arguing the toss.
Post #182356 5th Nov 2012 6:37pm
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
I removed my LR step and i fitted one of the ones that bolt to the towbar i find it more solid and reasuring
Post #182366 5th Nov 2012 6:50pm
Mo Murphy
Fixed linky Smile The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #182411 5th Nov 2012 8:24pm
megatoad
Inigo wrote:
Link to PDF here:
Cheers Inigo
I am waiting for my local dealer to call me back so I could question them about it.
Its an 06 TD5 but I am still paying for extended warranty so as you say it may be worth asking about them fixing it.
As for changing to a towbar step, I use several interchangeable Dixon Bate plates, (Alko for caravan, 50mm for scout traillers and a Nato for the Sankey if i ever fix it)
JC He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #182430 5th Nov 2012 9:17pm
MartinK
I didn't like the folding one, so I fitted one to the rear tow bar mount:
and
Works great, less complex, it's galvanized so hasn't rusted (I painted it with bvlack hammerite).
I'm sure it was only around £15...
Lots available on t'internet like this
A double one is available from a site sponsor:
http://shop.defenderbits.co.uk/towbar-step...-889-p.asp Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #182492 6th Nov 2012 7:17am
speedymarktd6
Thats what ive got works great Thumbs Up
Post #182534 6th Nov 2012 10:38am
