Home > Technical > Tdci
landyman37
Tdci
Hi all anyone know what can network the tdci runs on and if anyone can do a analogue to can interface
Thanks phil
Post #181376 2nd Nov 2012 5:39pm
dgardel
Italy
http://www.waeco.com/en/6018.php Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #181379 2nd Nov 2012 5:50pm
landyman37
Thanks I have emailed them.
Phil
Post #181382 2nd Nov 2012 6:04pm
landyman37
Phil
Looks like that is analogue gauges to can sensors
Thanks for you help
Phil
Post #181509 2nd Nov 2012 9:54pm
landyman37
Anyone else know anything
Phil
Post #181710 3rd Nov 2012 4:59pm
wslr
It is a standard high speed CAN linking the engine control unit to the instrument pack module.
Post #181917 4th Nov 2012 10:45am
landyman37
So should the can signals be the same as the can signals that the td5 engine uses. What I am asking is would the td5 ecu connect with the tdci dash
Phil
Post #181918 4th Nov 2012 10:50am
wslr
Off the top of my head, the only CAN on a Td5 was on Discovery2 using the ZF autobox.
Post #181924 4th Nov 2012 11:10am
Martin
Site Admin
No CAN on Td5 Defender, everything hardwired.
Only CAN on Puma Defender is HS-CAN between Engine ECU and Instrument Pack (and OBD socket)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #181925 4th Nov 2012 11:12am
landyman37
Hi Martin if you look at the pin out diagram for the red plug on the ecu it shows there are a can pos and a can neg
Phil
Post #181931 4th Nov 2012 11:21am
Martin
Site Admin
Which pinout?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #181999 4th Nov 2012 3:41pm
landyman37
Martin wrote:
Which pinout?
I have got a list of PIN numbers on my PC it says I think it's 34 and 30 (or up that way some where are can inputs outputs) I will have to check which ones for deffo when I get in my pc later
Phil
Post #182001 4th Nov 2012 4:11pm
dgardel
Italy
Phil
Quite hard, TD5 have not CAN....
Se here for more interfaces
http://www.ross-tech.com/vcds/interfaces.html
and
http://www.samtec.de/en/hauptmenu/produkte/hardware/hslight-ii/ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #182031 4th Nov 2012 5:38pm
landyman37
Give that man a buiscuit just looked through and yes it is a discovery 2 CAN high pin A35 and CAN low A32.
Back to the drawing board.
Phil
Post #182117 4th Nov 2012 8:37pm
