![]() | Home > Maintenance & Modifications > Before the god of ice takes care of my fuel filler cap |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
What about a Defendoor?
http://www.defendoor.co.uk/ Obviously I have no experience with frozen fuel caps here in Africa........ ![]() |
Kraut Member Since: 28 Dec 2011 Location: Westphalia Posts: 336 ![]() ![]() ![]() |
I was thinking of purchasing one of those, but only as a second-best solution. They don't look too good and I heard they are getting stolen quite often
Stolen.....you serious?
Mine has been on my Defender for 6 months now and haven't been knicked yet, EVEN IN AFRICA ![]() Really do not look bad and you can customize as you please. Is the problem the water/snow/ice that "blocks" the cap or is more due to the temprature below freez point? If it is due to temps I do not think it will help but if it is due to water/ice ingress I am sure it will help somewhat? |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
Just ordered one - will let you know what it's like. 2007 TD5 90 Hard Top
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Me too
I was thinking of attaching a loop like on the fuel cap to the defendoor to stop leaving behind ![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Thanks for the advise mates!
There is a nice upgrade-kit available, but because of my limited technical abilities I was looking for a simple cap-replacement with an adequate sealed lock that prevents diffusing the moisture or dust to the inside, so the lock could not be blocked anymore. Maybe anyone found a cap from another car-manufacturer to fit the puma!? http://shop.ex-tec.de/product_info.php?products_id=184 |
![]() ![]() http://www.defender2.net/forum/topic11700....=defendoor If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Your more likely to leave a Defendoor behind than have it nicked. Guess how I know. My excuse was I was being rushed at the pumps.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Been caught out once before, arrived at a service station early one Saturday morning on the way to some green lanes in Wales. Nearly out of fuel, couldn't get the fuel cap off. Spent the next 15 minutes anxiously battering the lock with a hammer and screwdriver ! Eventually got it off and was able to reuse but not lock.
Lesson learnt keep well oiled or cover the lock on the cap ![]() |
That' exact what happened to me, only the second time it took more than half an hour hammering onto this
This looks awesome! ![]() We need a UK seller (Forum Sponsor) for one of these or something similar ![]() Brendan? Andrew (Defenderbits)? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
don't forget that fresh human urine is very good at de-icing!
more a skill for the boys in directing it where you want it ![]() |
jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268 ![]() ![]() ![]() |
A tip I was given Is in addition to the defender door put an old oily rag on top of the filler cap this helps to prevent moister getting into the cap and freezing.
Jason. |
FG - Yeah until it get's into the fuel system / tank. Try explaining that one.
