![]() | Home > Maintenance & Modifications > Wolf Air Intake Grill |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6143 ![]() ![]() ![]() |
IF you fit them as a pair, along with the internal pipework, then yes, some advantage as you can list over and cover one wing with water, but the engine will still be able to breathe through the other side.
Although IMO far easier to add a RAI.... just as the MoD did to a lot of the vehicles, removing one (or both) of these wolf intakes and just having a raised intake.... although I suspect this was more for dust intake rather than deep water wading. |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
The whole idea of the above was for the prevention of water 'splashes' into the intake pipes. Completely pointless paying for it unless it is for looks.
Glyn ![]() ![]() |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2962 ![]() ![]() |
It gives you around 6 inches more wading depth too supposedly
How does that work? |
Theres a sort of bulkhead inside which is almost at the top of the grill if that helps
thanks
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
As much use as a button on a sock
