Home > Puma (Tdci) > Trailer electrics |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
My head light come on some times when i break with the trailer on NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
6th Nov 2009 9:25pm |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Trailer flasher should come on when indicating (unless trailer has LED lights in which case there's insufficient current draw to trigger it, but the trailer lamps still work).
Everything else on mine works normally. Braking certainly doesn't make the headlight lamp come on on the instrumentation or the side lamps or anything else. I have a small trailer with standard bulbs and I get nothing strange. My camper trailer is all LED and so I don't get the trailer indicator flashing on the instrument panel. But that's the only difference. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
6th Nov 2009 9:33pm |
I should get it looked at as its not good but the trailer is new so i can't see it being that
The trailer is an ifor Williams and has got a reputable name it must just be one more fault the defender has NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
6th Nov 2009 9:40pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
If the lights come on when you brake, then that's usually an earth fault, either the towing socket, the trailer, or a cr@ppy connection in the plug & socket itself.
Try running a piece of cable from the defender chassis to the trailer chassis...clean bare metal points on both! (just get some helping hand to hold it in place) and see if that cures it. you'll know it's an earth then |
6th Nov 2009 10:48pm |
Cheers d-j i'll try it latter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
7th Nov 2009 9:23am |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Yes, as said above. If in doubt check earth connections. Nothing should happen other than the trailer indicator flashing when indicating to show that all the electrics are working fine. If a bulb goes on your trailer, the trailer indicator will stop working as a warning.
7th Nov 2009 11:30am |
