Home > Puma (Tdci) > Suspension lift. Light version
Page 2 of 3 <123>
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
I'm waiting for Scola shocks standard height because my garage is low and 110 passes barely so.
I'm looking for rear spring a bit more strong, do you know the Rate (lbs./In.) of the original springs? Matteo
Defender 110 Td4 SE MY 09
Post #17831 4th Nov 2009 3:15pm
MK
the myth says 270-420 lb/in for rear Puma 110" SW
Post #17834 4th Nov 2009 3:48pm
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
MK wrote:
Why donīt you try with Gwyn Lewis spring spacer? They are very good and you can choose for 1 or 2".
MK
I have sent them 2 emails (yesterday and today). No response Crying or Very sad
Post #17849 4th Nov 2009 6:56pm
MK
well, sometimes happens Puma 110" SW
Post #17860 4th Nov 2009 8:36pm
jamesbond007
Well, I did get a reply early this am.
I'll do 1 1/2 in front and 1 rear.
Post #17880 5th Nov 2009 8:18am
MK
A word of caution: I`m not sure if you will get issues with your front propshaft going over 1". I lifted 2.5" and I decided to fit a DC propshaft right away. Also for safety reasons. In your case I would fit the spacers and see what happens. Puma 110" SW
Post #17882 5th Nov 2009 8:49am
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I feel sure you will get prop/drive shaft issues. Puma's dont like to be lifted. Try the spacers its a cheap option.
Allan
Post #17931 5th Nov 2009 11:45pm
jamesbond007
I am now doing 1 inch all round.
Post #17934 6th Nov 2009 8:45am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I've got the Bilstein shocks and the H/D Bearmach blue springs on and its give me a 1in lift and an Excellent ride with no issues Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17948 6th Nov 2009 5:38pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Hi 007,
I am thinking of doing the same thing too.
Can you give us an update of what happened?
Did you end up getting DC propshaft after the 1 inch lift?
THanks
Martin
Post #425460 22nd May 2015 3:37am
MalteseRover
Malta
Hello,
When i got my 2003 110 3years ago, previous owner added a 1" spacer under the front springs.
are 1" lifts considered mild and within safe zones? Not causing complications to steering/suspension/toe in/castor angle interference?
I have been experiencing death wobble recently since summer 2020. Panhard bush changed twice now Sad Could this be linked?
joseph
Post #877190 8th Jan 2021 10:59pm
Generally, a 1 inch lift would be considered mild and not require any further mods. Your recent 'death wobble' is more likely to be connected to swivel pre-loads, particularly as the lift has been in place for so long. Darren
Post #877196 9th Jan 2021 12:01am
jst
35mm was the perceived max lift fit a puma without upsetting prop angles. Engine to t box angles are different in puma to other engine/gbox variants. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #877210 9th Jan 2021 8:16am
camelman
I'm running a 50mm lift using Glyn lewis spacers and original springs and shocks. No propshaft issues.
Post #877218 9th Jan 2021 9:07am
Josephs 110 is a 2003 model, so pre-Puma. Darren
Post #877230 9th Jan 2021 9:50am
Page 2 of 3 <123>
