![]() | Home > For Sale & Wanted > Rear dislocation cones or similar for 110 |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 ![]() ![]() |
Before I buy a set, or worse, make a set, does anyone have anything sat around doing nothing they might want to move on?
Cheers Mark |
Well I bit the bullet and made a pair! Might even take some photos later when they are finished. Curse this
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Or market it, as a 110 anti-handling kit ,, bound to sell on here ![]() ![]() Main Brian James Trailer Dealer for South West UK |
I have added a modification to the antiroll bar to prevent it from inverting. Need to give it a good testing but I reckon that it is now fixed!
Can you explain a little more? What was the issue & how have you fixed it? |
My issue is that I am running +2" shocks with standard springs. Not an issue in itself and easily fixed with a set of home made Dislocation cones. More of an issue is the fact\that I am running an anti roll bar on the rear (and front) which really help with the handling. However, despite fitting 2" spacer blocks to the ARB mount a situation arises (only on one side!) when on full droop the axle moves so far that the antiroll bar and the axle link align into a straight line. When the axle returns to the level, rather than the link falling back down it has been going upwards, ie. inverting. This places a huge strain on the ARB and the mountings and actually causes the truck to crab as the trailing arm bushes try to take up some of the forces. Not wanting to limit my articulation I wanted a simple solution to simply stop the ARB/link combo from being able to pass the point at which inversion could occur. So basically I made a shackle that fits below the joint and is held on by the bolt through the arb link and the end of the antiroll bar. Now when at full droop it is impossible for the ARB to become completely horizontal so when unloaded it HAS to go back down rather than up. I will be keeping an eye on it but a few tests have shown that it works fine.
Hopefully I have explained it OK. Will take a pic if you are interested. |
OK think I've understood - thanks for that
![]() Photos would be good if you have the time... |
