Home > My Defender > What Did You Do In Your Defender Today |
GrahamB Member Since: 05 May 2012 Location: Clackmannanshire Posts: 7 |
Just edited, my post! As found the post on rustproofing!
Thanks I have already fitted a mantec swing away wheel carrier, towbar and electrics(which were mounted in the hole in the rear cross member) 28 mpg MAX! |
26th Oct 2012 1:58pm |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
not today, fifteen days ago, but....Fitted my new (although bought in May!) intercooler... Very happy...had one or two troubles, most solved, except the one that the intercooler tightens an AC pipe...but all is working! I'll check it regularly!
Click image to enlarge Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
26th Oct 2012 4:12pm |
Which brand intercooler please? Any better pics of the problem area? I'm fitting an Alisport next year so any info most welcome Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
26th Oct 2012 5:07pm |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 |
I managed to pop into a local garage to pressure wash most of Salisbury plain off the landy after last Sunday's play time. Now all I have to do is wash it properly by hand tomorrow and detach all the long grass from the various drivetrain and suspension components.
26th Oct 2012 5:30pm |
B&A ?
He is a great guy..... It is nearly 5th November ! |
26th Oct 2012 5:33pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
You are playing with fire there Greeni. Just hope nobody reports you to the Headmaster otherwise you will be staying back in detention under school rule 37iib Brendan |
26th Oct 2012 5:39pm |
@ Brendan, it's a none committal comment
26th Oct 2012 6:08pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
Ok spent 7hrs in the DC today, drove from Dartmouth in south Devon to Guildford to drop daughter back at her mums then straight down to Lymington in the new forest to spend the rest of weekend in the Motorhome which the wife drove up from Devon
Only had a 20 min break at the services near Stonehenge didn't even bother to get out Great drive didn't miss a beat loving the DC It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
26th Oct 2012 6:09pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 |
I was 20 minutes early for the ferry so I managed to get to jet wash most of it off on the way home and then gave it another power washing Monday evening before it got dark. Will be out early tomorrow to get the rest off. |
26th Oct 2012 6:37pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Had a look at a potential Big Black replacement.... An Astra - only 6months older than Big Black, slightly above average mileage, but it is absolutely spotless! It will have to be known as Little Black, or if Jessica gets her way, Baby Black
Getting back to me on Monday with a trade in price, although I'm not getting my hopes up... |
27th Oct 2012 10:58pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
did stage 1 of the webasto install...sort of enjoyed it!
27th Oct 2012 11:04pm |
Abu Buckwheat Member Since: 25 Sep 2012 Location: Philadelphia & Abu Dhabi Posts: 10 |
I Brewed up Double Espressos in the Moreeb Dunes in the Liwa Oasis
Click image to enlarge Then Visited the Biggest Defender in the World at the Rainbow Sheikh's car musesum ... FYI TYhis Series 3 is a Freaking Cafe Grocery!!! Click image to enlarge Click image to enlarge [/img] "Simba" - 1988 LR Spec vehicles Defender 110 HT w/V8 - Schumacher-Like Exped Build "Kimba" - 1986 LR Defender 110 CSW w/ 4.6 Rover V8- All White Alpina (Sold) "Gemma" 1985 110 CSW 3.5L V8 - Connsiton green (in USA) "Gopher" - 1984 LR 110 CSW 3.5L V8 - Brown (in USA) "Baby Duck" - 1997 D90 - 4.6 L RR engine - White (in Dubai) "Big Bird" - Sandringham 6 - LR 150 - 3.5LV8 - Horrible School bus yellow (in Dubai) "Minerva" - 2005 110 TD5 CSW - Silver (Sold) |
28th Oct 2012 3:11am |
fitted the seals to the custom top box, started to line up the airheater fittings ... still loads to do for the trip
28th Oct 2012 8:08am |
I sprayed my steel conduit saddles black, that are going to go around the roof rack rails and screw into the Wisa board. The bolts on the standard SD rack don't stop the board 'flapping' and making noise with wind speed, so a bunch of saddles will do the trick, these saddles are what I also hold the Foxwing with.
28th Oct 2012 8:55am |
