Home > Td5 > thermostat / normal operating temp. |
Sounds normal, even.with the cooler heater. Take a look at the controls on the top of the heater box, easier if you get someone to move the leavers in the cab so you can see which is which and also which way round they go. You may find that you can "gain" a bit more as the hot setting inside may not be putting the lever on the heater box in the full position.
18th Oct 2012 2:47pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Mine sits just below 1/2 - I read somewhere that this was the normal position, if there is such a thing !
Should add that it has just had a new thermostat. Agree with JWL, check that on full heat the lever on the heater box goes all the way over, on full heat mine still had about 1/2" of extra travel at the box end. Still need to adjust the cable ! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
18th Oct 2012 2:48pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
My temp gauge sits at just below 1/2. Yours sounds a little on the low side. If the heater lever on the matrix is not moving fully that would affect the temp in the cabin, however it will make no difference to the temp gauge.
Suggest check thermostat is not stuck open, have you noticed it takes a long time for the temp gauge to get to 1/3, that would also suggest thermostat stuck open. 2007 TD5 90 Hard Top |
18th Oct 2012 7:18pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
It should be at 88.2deg Celsius.
Slightly to the left on the middle. Mind you, the gauge is not linear. It starts moving around 65deg only. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
24th Oct 2012 3:32pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
That's probably the temperature at idle.
You usually see around 95 degrees when the engine is running under normal conditions. |
24th Oct 2012 7:40pm |
