![]() | Home > Maintenance & Modifications > Emergency Lights Blinker |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Hi,
I promise... I have searched, and browsed the forum and although I know it has been discussed recently I couldn't find the thread. The thing is, that the emergency lights switch in my Oct 2007 Puma, has stopped flashing when I switch on the emergency lights (blinker). I assume it is just the small bulb inside that died, can someone confirm this? and hopefully how to extract the bulb? (I know how to remove the switch from the dashboard) Thanks guys, ciao ![]() |
Yes sorry, emergency lights work flawlessly.
I think is stupid to replace the whole switch if only a small light bulb can be replaced, no? |
The bulb is replaceable and the details are buried in THIS THREAD Darren
agree it should be servicable, have you prized the front off the switch ?
to take the centre dash off, remove radio/cd unit, undo the torx screws and it should come off, there are threads on dash removal. then you should be able to take the switch out of the dash.. let us know how you get on |
Hero! |
