Home > Puma (Tdci) > Removed earth and ... |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
On the 110 (2009) without the backup alarm you just remove the negative as normal.
On the TD5 which has got a backup alarm there is a specific sequence that has to be followed to remove the earth. Also, if you fail to follow the removal procedure there is a specific way to restore power and stop the alarm. I guess the 2012 with a backup alarm will have a set sequence to be followed. Have you had a look in the owners handbook ? Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Oct 2012 6:21pm |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 |
Absurd as this sounds, I've just read the very thin owner's handbook,
"Your vehicle may be fitted with a battery backed-up sounder that operates as an anti-theft siren. It will activate when the battery is disconnected unless disconnection is made within 15 seconds of removing the starter key from the starter". Problem solved. PS This information is open source so there's no security threat with this thread. |
21st Oct 2012 6:49pm |
