Home > Puma (Tdci) > Suspension lift. Light version
Page 1 of 3 123>
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
Hi
I am considering a suspension lift. Essentially for looks (110 Crew Cab).
Can you recommend a kit?
I don't want to have to change anything to the transmission, so it would have to be a light version, not a hardcore one. I do not carry heavy loads and I don't like the fact that my Defender is lower in the front than in the rear. I would like to have it level.
Thanks.
PS: please don't get technical on me, I know very little. It will be installed by my local mechanic. Do I need to change only the springs or the shocks as well?
Post #17743 3rd Nov 2009 12:34pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I have ome on the front about 40-50mm lift with no problems, and no changes to the transmission
Post #17744 3rd Nov 2009 12:53pm
jamesbond007
Thanks. Which ones exactly? Only the springs?
Post #17745 3rd Nov 2009 12:57pm
Sonic3d
Hi Georges
I have the 751 fitted to mine but i do have a heavy winch and bumper, if you don`t have any extra weight on the front you could use the 761`s these will give you a 50mm lift.
Take a look at the link below its very helpfull Thumbs Up scroll about half way down
http://www.expeditionexchange.com/ome/indexsprings.php
Post #17746 3rd Nov 2009 1:14pm
jamesbond007
Hi
I was actually just looking at that. It looks like 761 in F and 755 in the back.
Should I use trim packers to make it level?
No change necessary to the shocks?
Post #17747 3rd Nov 2009 1:19pm
Sonic3d
I haven`t used the trim packers and it sits level and im using the std shocks Thumbs Up
Post #17748 3rd Nov 2009 1:22pm
MK
I got OME all around. 751 F and 755 R. But, pay attention. I got 1" in the back and not evern closer to 2" as OME advertise.
OME USA acknowledge their specs are outdated so they will pay for the missing inch in the back. I also doubt 761 will give you any lift.
Why donīt you try with Gwyn Lewis spring spacer? They are very good and you can choose for 1 or 2".
MK Puma 110" SW
Post #17751 3rd Nov 2009 2:01pm
jamesbond007
Thanks for that. I was actually looking at spacers with not much luck. This helps a lot. Thumbs Up
This might be an easier and cheaper solution for what I want to do.
One inch would be fine for me.
Post #17760 3rd Nov 2009 3:30pm
jamesbond007
I'm thinking either:
- one inch front only
- or 2 inches front, one inch rear
so that it sits level.
Post #17768 3rd Nov 2009 6:03pm
You don't mention if you've got a winch or anything fitted, but i tried some 110 HD front springs on my old 110 (factory HD;s, which are just 90 standard rears) and that lifted it a good inch, maybe slightly more.
however it made the steering very vague.
Personally i prefer the "high" back end.
Post #17792 3rd Nov 2009 9:01pm
jamesbond007
no winch
Post #17804 3rd Nov 2009 9:54pm
MK
I would leave the rear 1" higher than the front. Puma 110" SW
Post #17807 3rd Nov 2009 10:26pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I did a 2" OME lift to my 110 and it caused all sorts of drive shaft and vibration issues. I removed the springs to remedy this but due to the weight of the bar and winch the front went down considerably. I have found that the standard LR 130 springs lift the front to an almost verticle with the rear.
Allan
Post #17816 4th Nov 2009 6:27am
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
I fitted a set of Brit Part "Standard Height" HD springs to my last 90, along with their Super Gaz shocks. It made it sit 1" higher than before. Mind you this could have been purely because the old springs were past their best. Very Happy The good thing was that the ride was still quite compliant and not as stiff as I expected.
I know a lot of people knock the quality of Brit Part gear but I was more than happy with their performance and quality.
The best part was no effect on steering or propshafts and I didn't have to inform my insurance company as it was not a suspension lift, merely replacement parts. MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #17823 4th Nov 2009 1:29pm
jamesbond007
It looks like indeed the 130 sits more level than the 110:
Post #17824 4th Nov 2009 1:33pm
Page 1 of 3 123>
