Home > Puma (Tdci) > Drive line noises
mse
Drive line noises
I know this is always a difficult one...but whats "normal" and what should you be concerned about?
Im thinking whines, clocks and knocks.
Since the engine update was applied I can hear more - then remembered its a defender and not a quiet as the disco or freelander...but, when is it prudent to flag it not to be told "they all do it" Mike
Post #17563 1st Nov 2009 5:09pm
Willie
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
Hi MSE,
Same experience as you. Since re-map I can hear every knock, clunk and whine and am becoming paranoic. In addition I have just replaced the wheels for a new set of boost alloys with Grabber 235x85x16. I think I will resort to a pair of ear defenders, it has the added advantage that I can no longer hear the wife nagging me as to why I traded in my Merc ML270.
Willie Defender Virgin
Post #17568 1st Nov 2009 6:09pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Hi mse
The only clunk i get is when changing up a gear and only when im not quite going fast enough for the next gear, usually going into sixth. Otherwise mines clunk free. I have got the rear diff whine when decelerating from above 80kmph.
If it annoys you often enough take it to the dealer. 130 crew cab
98 V8 Disco
Post #17569 1st Nov 2009 6:11pm
mse
I have a slight clunk on take up and a whine at motorway speeds.
It being quieter im certainly noticing more, if the whine was there i hadnt heard it before...the clunk i think may have happened before; the new clutch and selector removed most to all the noises...but this update certainly makes more noticable! Mike
Post #17583 1st Nov 2009 7:58pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Every Land Rover I have owned (nine to date) has had a clunk on power take up, the older and more worn it was the louder the clunk
I have therefore assumed it was normal Very Happy MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #17613 1st Nov 2009 11:13pm
mse
I understand you - but this wasnt present on the new 2 ive driven, ill see if my disco does it - maybe they were broken Mike
Post #17686 2nd Nov 2009 7:22pm
