Home > Maintenance & Modifications > can you put utility sides onto a standard 110 ?
NCTT
ok so here is the deal i want a utility BUT not many about privatley and i begrudge paying 20pc vat for essentially exactly the same car
can u mod a 110 to make it a utility ?
Post #176806 18th Oct 2012 12:29pm
farmer giles
yes you can but it won't change the tax status.
also i beleive you can only use 110 sides as the 90 hardtop side length is different.
try equicar for parts Thumbs Up
Post #176811 18th Oct 2012 12:52pm
NCTT
hmmmmmm , thanks farmer
appreciated
Post #176812 18th Oct 2012 12:58pm
The rear sides on a 110 USW are (I am told) the same length as those on an 88" (but not a 90").
You could convert a 110 DC to a USW and maintain the tax status but it is a lot of work, since you'd need to change the rear buck, rear cab panel and roof. The roof should fetch plenty on on ebay though.
Post #176817 18th Oct 2012 1:22pm
NCTT
blimey sounds like aklot of hassle
ill pass and keep my eyes open !
Post #176820 18th Oct 2012 1:47pm
Timo K
Finland
I had my 110 STW converted to a USW by Foley's. You can get the sidepanels from them. About £200 or thereabouts? No big deal. Cheap and easy.
Post #176822 18th Oct 2012 2:02pm
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
You could convert a 110 DC to a USW and maintain the tax status but it is a lot of work, since you'd need to change the rear buck, rear cab panel and roof. The roof should fetch plenty on on ebay though.[/quote]
2 Days work at most once you have gathered all the parts together! Smile
hardest part for me was converting full length van sides
Post #176823 18th Oct 2012 2:03pm
udderlyoffroad
Correct - currently have some 88" sides bolted on to my 110 CSW tub. You can pick up an 88" set of vansides for not much on ebay as series folk convert their vans to station wagons. I paid £45 and that included a roof and windscreen! Note however that 88-ers have rear quarterlights wheras USW sides do not. If security for gear was your concern it wouldn't take much to get these tinted - even a DIY ebay kit would cost less than £20 for both.
As has been mentioned, none of this helps your tax problem - surely a chat with your account would help you justify a USW.... Whistle Real trucks don't have spark plugs
Post #176834 18th Oct 2012 2:41pm
