![]() | Home > Puma (Tdci) > Windscreen replacement |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1820 ![]() ![]() ![]() |
I swapped the heated screen & rubber out of my 100" into th ePuma a couple of weeks ago (was used for less than a year before I put it in the garage when I bought the Puma), and I'm sure both rubbers have a 'double lip' around the outer edge against the body.
I sealed the new one into the Puma & all ok, I ran out of time on the 100" and it leaked like a pig until I sealed it. Best of luck. Keith |
From another thread....follow the link....
![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 ![]() ![]() ![]() |
Just had replacement screen in my puma...heated as well
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
Who fitted it and does it leak? |
My hubby fitted it and no it doesn't leak....he's been in automotive glazing for years
Ah, trade connections!
The reason I ask is that I have a heated screen stashed in the house, and an unheated screen with several stone-chips and cracks in the Defender, and need to get them swapped. I am trying to figure out who best to get to do it, bearing in mind the tales of leaks etc. Best local quote sofar has been £90 from Gavin (of special resin fame). I was thinking of doing it myself as I have done quite a few traditional flat class rubber-sealed windows in the past, but it is a rather expensive piece of glass to risk if it goes wrong. |
I asked Autoglass for a price to swap a read heated screen recently and they quoted me £120
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 668 ![]() ![]() ![]() |
Supposedly fixed today, we'll see if my feet remain dry
Shame your in Dorset and not nearer to midlands,we could have replaced it for you ![]() |
It is a shame! Would have been great to have a Landrover glass specialist do it! Can anyone recommend a windscreen fitter in the Poole/Blandford area of Dorset who can do a good leak-free job on a Defender at a sensible price? |
[quote="blackwolf"][quote="ClaireWright"]
Shame your in Dorset and not nearer to midlands,we could have replaced it for you :-)[/quote] It is a shame! Would have been great to have a Landrover glass specialist do it! Can anyone recommend a windscreen fitter in the Poole/Blandford area of Dorset who can do a good leak-free job on a Defender at a sensible price?[/quote] |
When replacing heated screen you have to seal rubber wear tags are. Even if you fit new rubber because we're tags are soldered to screen a small piece of glass is removed to solder tag to buz bar that's why they can leak water passes down and back up into car were tags are as there's a hole there :thumbsup:
Blackwolf, sorry for the delay must have missed your post....
Autoglass, behind Castlepoint.....Send me a 'pm' and if convenient we'll hook up for coffee and a chat....Sorted out my water ingress woes... ![]() Treat every day as if it is your last....one day you will be right!! |
What are wear tags Claire and where are they? I've not noticed anything additional on my screen other than the 12v connections? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
