Home > Technical > 110 front suspension height
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Hi,
I have a 110 td5 hicap that I think is a bit low at the front. I have fitted a winch bumper which may well have something to do with it.
I have been looking around at a suitable pair of springs to give the front end a lift but am at a bit of a loss as to what the actual standard height at the front should be.
I don't want to fit some nice 2" lift front springs to find that I have lifted it by too much because of the original "saggy" springs.
Can anyone recommend a pair of fronts that will lift the front of the standard 100 hi cap with a winch / winch bumper on the front?
Cheers,
Dave
Post #175822 14th Oct 2012 11:06pm
110 HD fronts, AKA 90 standard rears do the job perfectly (as fitted by the factory)
With no winch etc fitted, you'll get about 1.5" of lift but with a winch the height is more or less standard.
and they're cheap.
Post #175838 15th Oct 2012 6:54am
Glynparry25
Dave,
I have had the same problem with mine (TJM bumper, Spots and upgraded winch.
My choice in the end has been togo for OME 751s. They should bring it back to standard height/ maybe a little bit higher.
I am a firm believer in fitting upgraded equipment when it needs changing so will be fitting Koni shocks/ turrets and HD turret rings at the same time.
Glyn Dog Sheep
Post #175844 15th Oct 2012 7:02am
v8bobber
Thanks for that,
Ideally I could do with an inch or so above standard as the winch sticks out the front and reduces the approach angle somewhat. Adding a slight lift would go someway to restoring this.
Additionally, I dislike the "nose down, arse up" look however I appreciate I cant really lose this entirely.
So suggestions of a plus 1 lift, with the weight of the winch, would be perfect.
Thanks for the help so far,
Dave
Post #175860 15th Oct 2012 8:03am
jst
spring spacers? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #175888 15th Oct 2012 9:26am
Bodsy
I put 110 std height HD springs and shocks on the back, should I put HD on the front, has a winch bumper, but no winch yet will it make it too strong or should I stick with some new STD springs? Don't want to lift it really, although it will be higher than the worn out springs currently on the front I know Thumbs Up Over on D3
Post #175902 15th Oct 2012 9:56am
rustandoil
My 110DC sat nose down, i have recently put Famous Four +1 inch springs on the front and it now sits level, but has raised it over 2 inches measured at the front bumper
Post #176421 17th Oct 2012 5:02am
rustandoil
Post #176423 17th Oct 2012 5:29am
Glynparry25
Depending on winch and bumper will indicate height.
I have a TJM bull bar: 25-30Kg
Upgraded 8274 winch: 55Kg (inc failead and hook)
Lightforce Blitz 240s: 2Kg
So I have approx about 80Kg over a normal bumper.
If you go for a smaller winch and regular winch bumper you will only have something like 40-45kg over normal weight so if going for OME 751s they will probably have about a 1-1.5" lift.
Why do you need the clearance at the front?
110 as standard has an approach angle of 49 degrees, but a departure angle of 35 degrees. If you approach a slope at a 45 degree angle the front will clear, but then when your rear end gets there it will dig in and you will be going nowhere quick. If you drop the front by 1 inch with a winch you will probably still have a 35+ degree approach angle.
Glyn Dog Sheep
Post #176438 17th Oct 2012 7:31am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I have a heavier bumper, a warn 9500HSi and will have a bull bar with lights...As someone mentioned above, I fitted HD springs to the front of my DC...And they're fine! It's levelled and performs well... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #176475 17th Oct 2012 10:00am
