![]() | Home > Technical > Diff lock |
The bulb should be tested every time you turn the ignition on. Does it light up then? Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17606 ![]() ![]() ![]() |
Could be a faulty or badly adjusted switch.
Easy enough to test the CDL, jack up one front wheel and with gearbox in neutral engage CDL. If the wheel turns the CDL isn't engaged. |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
Mines never lit up, apart from when the diff is locked, never lit up when the ignition is turned on though. |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 668 ![]() ![]() ![]() |
Mine sometimes doesn't light up, but a good wiggle of the lever usually sorts it
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8171 ![]() ![]() ![]() |
the light shouldnt come on as part of the ign on cycle/checks Cheers
