Home > Puma (Tdci) > oil in coolant |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Take it back and get them to sort it out NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
7th Oct 2012 7:14pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
head gasket by the sounds
7th Oct 2012 7:15pm |
frogface65 Member Since: 25 Dec 2013 Location: kent Posts: 5 |
Hi
Had the exact problem , heater stopped working smell of hot oil & loads of mess black sludge oil all over engine . Dealer did same not sure what long term damage has been done . J ust wondered what happened ? |
25th Dec 2013 7:25am |
jameshope Member Since: 07 Oct 2012 Location: york Posts: 3 |
18,000 m later and a service all well with no issues at all. I think with limp mode and auto shut down these engines are good at looking after themselves!
28th Dec 2013 8:04am |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
Afternoon all,
Ah the joys of the transit dura torq engine. Yes your oil cooler / heat exchanger will get us all and there`s not much we can do but replace it and spend between 2 and 5 hours, flushing the cooling system checking for limp, swollen hoses the hot oil weakens the rubber. I`ve found non bio washing powder or gel is very good at braking the oil / sludge down especially if you use really hot water going into the engine. its cheaper than flushing fluid and it does bubble up bringing some of the oil with it. Also change oil and filter in case of cross contamination, it should`ent happen due to oil pressure most of the time being higher than cooling system pressure but better safe than sorry.. Changed loads on transits, ldv convoy. Another gift from the mechanical gods happy new year. |
28th Dec 2013 3:33pm |
