Home > Technical > Headlight bulb replacement |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
Greetings from Africa!
Is there an easy way to replace the headlight bulb (without having to remove the whole damn unit)? Cheers www.ralton.co.za |
5th Oct 2012 7:46am |
No is the short answer, no access to the rear of the beam unit! You only have to remove the surround trim, pop out the indicator and sidelight, loosen off two screws and rotate the lamp assembly anti clockwise to release it. All in all no more that 5-10 minutes graft.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 5th Oct 2012 8:47am. Edited 1 time in total |
5th Oct 2012 7:52am |
cool, thanks
umm, and what is the standard bulb "spec"? www.ralton.co.za |
5th Oct 2012 7:54am |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
get the Philips X-Treme http://www.amazon.co.uk/gp/product/B00440C...01_s00_i00
They are so much better than standard ones. |
5th Oct 2012 8:02am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
Ralton, you could go all out and get these babies from AllMakes4x4
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
5th Oct 2012 8:59am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20347 |
It's one of the easiest jobs you can do. Just don't adjust the beam directional screws or you'll need the light's re-aligned properly. Only remove the one screw on the light bezel ring to remove the light body. be careful with it as it can be slippery! $W33T $0U7H3RN $UG4R
5th Oct 2012 7:00pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
As Steve says The only bezel screw you need to remove is the one in approx the 4 o'clock position on both sides. Guns and Landrovers .... anything else is irrelevant. |
5th Oct 2012 7:08pm |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 |
Naks
i can't find any details of those on their website, can you send me a link please, they look interesting. cheers |
7th Oct 2012 12:30pm |
