Home > Pictures & Video > Puma straight through exhaust sound.
Glynparry25
Sounds like Darth Vader has climbed up my exhaust- sounds lovely though when driving:
http://www.youtube.com/watch?v=wJZpGLPO6DM&feature=plcp
Not much to watch but I know many people have been asking what a puma sounds like with a modified exhaust- and when I was looking I couldn't really find anything anywhere.
It is an Alive tuning full exhaust (turbo to tail) and the only modification to it is me chopping the center box out and welding a replacement pipe on.
Hope this helps a few of you who are considering it..... oh, and it isn't noticeable at all with normal gentile driving.
Glyn Dog Sheep
Post #170192 23rd Sep 2012 3:18pm
Defender-Stu
Wow I love that sound Smile
Post #170201 23rd Sep 2012 3:45pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Yesterday i kept seeing and hearing Aston's of various types and they sounded great. I think the sound of yours is even better. More Sean Bean than Daniel Craig if you get my drift, tough, rough and throaty. Brilliant.
What's the noise like in the cab a fast cruising speeds? BM52
Post #170202 23rd Sep 2012 3:51pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
that does sound alot better than a standard 2.4
Post #170211 23rd Sep 2012 4:24pm
Killer90
Site Sponsor
well looks like ill be fitting a straight through at the weekend Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #170220 23rd Sep 2012 4:39pm
Glynparry25
I think my mpg is going to be going down..... I am constantly smiling from 2,000-4,000rpm and then change gear rather than changing between 2,000 and 2,500.
Chris.... I had a funny feeling you might like it. I am now considering cutting the small rear box off too.
If throttle is:
less than 50% there is no sound in the cab at all.
50-75% and you can hear it from 1-4th gear.... until wind noise is louder (about 50-60mph).
75-100% and it is quite loud.
Normally when cruising at 70-80 I am on about 20-30% throttle so can't hear it at all.
Glyn Dog Sheep
Post #170287 23rd Sep 2012 6:44pm
Killer90
Site Sponsor
id leave the back box personally, think it sounds lovely now Thumbs Up CSK Automotive
Post #170311 23rd Sep 2012 7:44pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Wow! I've changed my thinking from wanting one to needing one! Very Happy Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #170338 23rd Sep 2012 9:23pm
Sounds great Thumbs Up No Guts, No Glory.
Post #170341 23rd Sep 2012 9:30pm
ellebarto
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
So no negatives to making it straight through? I was planning to do this to mine but my mechanic reckons its risky because of 'back pressure to the turbo' and recommended I leave at least the back box in line somewhere!
Put me off a bit so it would be interesting to hear how you are getting on!
Post #173565 6th Oct 2012 2:26pm
Glynparry25
I have not experienced any negatives. I have not experienced any 'Booming' yet either.
Why do you want back pressure?
A turbo works from pressure difference. If you have 20psi at the manifold and 10psi back pressure from the exhaust the result is 10psi pushing the compressor wheel around.... if you then reduce the exhaust back pressure to 2psi suddenly you have 18psi usable pressure....... which results in lower temperatures, which is a good thing, also means the engine works less.
The more work your turbo does the higher the temperatures. VGTs aren't used in petrol cars due to them creating higher turbo temperatures which destroys the VG turbo. Also remember that the inlet air heats up as it passes through the turbo. The intercooler then brings the temperature back down to a more usable level.
So if air is entering the intercooler at 80 degrees C and then leaves at 45 degrees C............ the same air through a cooler turbo will say enter at 75 degrees C and then exit at 35 degrees C.
These are all just random figures to give an idea. The only way back pressure could be counter-productive on the Puma engine is if it some how went negative- which will never happen with so many kinks in the exhaust.
Maybe ask him for more in-depth reasoning and let us all know.
Glyn Dog Sheep
Post #173705 7th Oct 2012 9:24am
22900013A
Hmm, I rather like that.
Still wish I could make my 110 sound like this though -
&feature=youtube_gdata_player
Post #173708 7th Oct 2012 10:12am
That does sound nice.... wonder how loud it is in the cab though?
FWIW, i had a straight through pipe on my 110 (Td5), with a rimmer bros "sports" V8 tail section that I had on my old hi-cap
i ditched it a while back and put a standard system back on.... oooh for the quietness, it's deafening! much better than the booming that I had before.
Performance didn't seem to be affected either, so I'll stick with quiet.
Although, when I win the lotto, a Mercedes AMG 63 G wagon will sound just fine Cool Cool
Post #173712 7th Oct 2012 10:27am
ellebarto
Glyn Dog Sheep
I will do. A lot of that makes sense but then I have it in mind that the engine management is programmed with these kind of parameters and I wonder if back pressure form the exhaust isnt one of them? Its not that I want back pressure, is it that the car is expecting a certain amount and if you take it out of acceptable parameters it might start error coding? I'm asking the question thats all. I dont really know!
Post #173954 8th Oct 2012 8:54am
pom
would it pass an MOT ?
Pom
Post #173957 8th Oct 2012 9:08am
