![]() | Home > Puma (Tdci) > Doors stolen... time to sell? |
Welcome to the forum....
Never had my doors pinched in the first place, but I did carry out the modification....see link below.... http://www.defender2.net/forum/topic8589.h...p;start=15 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1393 ![]() ![]() ![]() |
My main dealer advised me to fill the bolt holes with araldite or ball bearings too. I have just used araldite at the moment, and last time I checked, they were still there. Euro-Leafing to infinity and beyond.....
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
has this been reported on Landywatch?
Bit of a sus first post IMHO.... |
Sus or not he's welcome to 'have a go' at getting my doors off. I'll give him predetermined timescale and then reap my revenge with my chainsaw and blowlamp on his nads if he's still there. ![]() Treat every day as if it is your last....one day you will be right!! |
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 ![]() |
Thanks for the follow-up so far.
Regarding my post being a bit 'sus' - it probably might have been 'sus' if I'd been asking how to remove a door that had been fixed with resin/ball bearings, but as it was I was just asking whether it made them secure. As it is I'm starting to think that some resin and ball bearings for the doors, and new hinges and a bike lock for the bonnet might just be enough to make the tea leaves go and nick someone else's doors. That and I'll sleep in it. Cheers Mike |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
don't give up on it as the scum have won there are things out there to stop this happening
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Ball bearings in hinge screw heads and decent cable lock on bonnet makes life harder for them .... did mine a while ago 'just in case'
![]() Another cheapish worthwhile deterrent - buy a cheapo alarm system [one of those 'only 2 wire connection' jobbies] and fit it inside your landie wired direct to the pos and neg on the battery. Then fit another earth lead direct from battery to the bodywork under seat somewhere. Those cheap jobbies work by sensing battery drain [when interior lights come on] so as soon as they open first door off go's the alarm ![]() Extra earth lead inside prevents them disconnecting original earth lead to kill the electrical system .... and even if they fuse out the factory alarm system the cheapo jobbie will still be on standby ![]() |
True. sorry if i am suspect but i do own a 110 with 4k worth of doors! sorry for your loss. i'd be going mental if some skank nicked my doors.....BUT i have my security in place |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Have a word with Kevin at mud stuff he has some good ideas on security
Thanks for the follow-up. Regarding the extra earth lead, is this just a simple case of connecting a new earth strap from the negative terminal to the side of the battery compartment?
Thanks again Mike |
